1974 Relay Board, No Fuel Pump Relay? |
ChrisFix |
Mar 26 2005, 07:34 PM
Member Group: Members Posts: 173 Joined: 3-March 05 From: Chapel Hill, NC Member No.: 3,707 |
My 1974 1.8 relay board has only one relay (Heater Blower) and one fuse (25 amp) installed. I thought all models had a fuel pump relay on the board as well? My fuel pump and car run normally (original fuel injection), so either PO did something creative or they changed this in '74.
I don't have the rear window defroster which I believe would use a relay on the relay board as well. What am I supposed to have on that relay board? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
scotty914 |
Mar 26 2005, 07:39 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
the fuel pump relay is in the double relay pack on l jet cars.
ChrisFix |
Mar 26 2005, 07:48 PM
Okay, what is the double relay pack?
ejm |
Mar 26 2005, 08:37 PM
I can see the light at the end of the tunnel Group: Members Posts: 2,691 Joined: 3-February 03 From: Massachusetts Member No.: 224 Region Association: None |
It's a combination control unit power supply relay and fuel pump relay, should be mounted over by the battery. It has two plugs, one with all white wires and one with color coded wires. L-jet cars also have a resistor pack that has five white wires going into it.
Mueller |
Mar 26 2005, 10:08 PM
the relay looks like one of these:
ChrisFix |
Mar 26 2005, 10:12 PM
Yes, I see now...Mine would look like that rusty thing.... (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
ClayPerrine |
Mar 27 2005, 10:15 AM
Life's been good to me so far..... Group: Admin Posts: 15,443 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
If you have to replace the rusty metal one, you will have to modify the plugs on the harness. The new ones only come in the plasitc, and you have to trim the outside of the plug to get it to plug in.
Also,make sure that you get the right relay. If someone sells you one for a L-Jet equipped VW, it won't work. They moved a ground wire from one side of the relay to the other. |
Lo-Fi Version | Time is now: 11th May 2024 - 05:24 AM |
