Get the great pumpkin home !, Clutch on the floor |
GreatPumpkin |
Mar 30 2016, 09:48 PM
Member Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None |
So my dumbass decides to bring my car up to school for the week. Not the best idea I know, but hey come on everyone loves the 914 up here in BG. Anyway I was about to go somewhere and I pushed the clutch in and it just went all the way down to the floor and doesn't come back up . I haven't had a chance to look at it yet. Anyone have any ideas as to what I should check for first when this happens.
Valy |
Mar 30 2016, 09:51 PM
Senior Member Group: Members Posts: 1,676 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Cable snapped.
Alphaogre |
Mar 30 2016, 09:55 PM
Member Group: Members Posts: 460 Joined: 28-May 12 From: San Diego Member No.: 14,487 Region Association: Southern California |
yea, had the same thing happen to me a couple months back. Its a 3Omin fix once you get the cable. Tangerine Racing has a Heavy duty clutch cable.
GreatPumpkin |
Mar 30 2016, 10:03 PM
Damn that blows haha I will look at it tomorrow any tips or common problems people run into when fixing this ?
Tom_T |
Mar 30 2016, 10:09 PM
Actually, the OEM GEMO clutch cables will last a long time as it is (they just go after awhile), & they're probably available closer to you at school for less coin on a student's budget.
Check & make sure that you have a good clean ground connection for the ground cable from the top of the transaxle to the underside of the trunk floor under there - I mean you need to unscrew, inspect & clean it. If some yahoo DAPO left it off, then you'll need to buy a new one & install it with clean nuts. Corrosion will be worse back there in salt, snow & rain country. If the ground there is bad or missing, then your clutch cable becomes the ground & gets fried quickly, & is the usual cause for short clutch cable life. For the parts numbers on all of these, see the free to download Porsche PET Parts Manual for the 914 which you can download for free as a pdf file from the Porsche website's Classics section under documents there. BTW - in a pinch to get to a shop for repairs with a snapped clutch cable, you can go a short distance by turning off the motor at each stop, then restart in 3rd gear - ride the broncin' buck - then cruise in 3rd & try to avoid stops. Distance you can go will depend upon how good your battery is, how tough it is starting each time, & how many times you have to stop. No major issue to fix these. PS - Remember that $hit happens - enjoy the 914, & the gals will enjoy it & you too - assuming you're single, that's okay! (IMG:style_emoticons/default/biggrin.gif) Good Luck & don't let this keep you from taking it to school in good weather! (IMG:style_emoticons/default/beerchug.gif) Tom /////// . |
Mar 30 2016, 10:30 PM
Another possibility is that the "Gordon pin" has failed. That is the roll pin that holds the clutch pedal arm onto the cross-shaft through the pedal cluster. The ones supplied with the Weltmeister bronze bushing sets aren't that good, the original ones are better. If you've rebuilt the cluster recently, that is a significant possibility.
--DD |
76-914 |
Mar 31 2016, 08:01 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,503 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
GreatPumpkin |
Apr 1 2016, 07:32 AM
found where it broke . Right as it goes through the firewall the cable frayed and eventually broke . Anyone know which way would be best to feed the cable . Hook it up at the transmission and try to run the cable to the front or hook the cable up at the front to the pedal cluster and try to run the cable to the back and then hook it up . Also is there any rule about how tight to make the cable once everything is attached . I've been looking at my Haynes repair manual , just been waiting for it to be nice enough to get underneath the car . Thanks for the help guys !
porschetub |
Apr 1 2016, 12:52 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
found where it broke . Right as it goes through the firewall the cable frayed and eventually broke . Anyone know which way would be best to feed the cable . Hook it up at the transmission and try to run the cable to the front or hook the cable up at the front to the pedal cluster and try to run the cable to the back and then hook it up . Also is there any rule about how tight to make the cable once everything is attached . I've been looking at my Haynes repair manual , just been waiting for it to be nice enough to get underneath the car . Thanks for the help guys ! Make sure you replace the clevis that threads on to the pedal end if it is worn,they are cheap to buy,my replacement GEMO cable was I little long so I cut 10mm off the pedal end,doing this give me more future adjustment at the gearbox end. There is also a cable retainer on the clutch roller housing that locks the cable into the slot,make sure you have that in place. Feed the cable in from the rear of the car once you have the car safely jacked up. Follow Haynes manual and you will be fine. |
GreatPumpkin |
Apr 1 2016, 01:43 PM
Looks like I have a window of nice weather so I'm gonna get under the car and give it a go ! Any tips on how to get the nut off the end of the cable where it connects to the pedal cluster ? It's hard to get on with a wrench so maybe some pliers ?
Lo-Fi Version | Time is now: 19th May 2024 - 07:00 AM |
