How's this 450HP in a 914? Will it bolt up?, I like it because it is a 4 and turbo |
rupert14 |
Mar 26 2005, 09:14 PM
Member Group: Members Posts: 76 Joined: 25-December 04 From: Prescott AZ Member No.: 3,339 Region Association: Southwest Region |
Will this adaptor fit our porsche trannys? What do you think it really puts out? I like it. A litte earlier than I planned for my big HP conversion but I will see what his reserve is.
Bob http://cgi.ebay.com/ebaymotors/ws/eBayISAP...ssPageName=WDVW |
Mueller |
Mar 26 2005, 09:19 PM
not sure if that particular adapter will work, if not, you can buy a new one from Kennedy for $450 or so with the correct flywheel.
the exhaust won't work unless you cut up the rear trunk......pretty cool motor and I'm sure it can produce that hp level, just for how long is unknown...pretty damn pricey but speed costs money (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) a 200hp subaru motor will be plenty to start with (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
scotty914 |
Mar 26 2005, 09:33 PM
suby torque rules Group: Members Posts: 1,525 Joined: 20-July 03 From: maryland, the land of 25 year Member No.: 924 |
i thought all vw trans had the same bolt pattern
and 180 hp suby is fun (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) |
jasons |
Mar 26 2005, 10:54 PM
Jackstand Extraordinaire Group: Members Posts: 2,002 Joined: 19-August 04 From: Scottsdale, AZ Member No.: 2,573 Region Association: None |
Even if the bolt pattern is the same, the flywheel is still not right. The flywheel for a T1 is what like 200mm and the flywheel for the bus T4 is like 210? Then, bus T4's have a smaller flywheel than the Porsche T4's. Something like that... I know the flywheel won't work though. |
TonyAKAVW |
Mar 27 2005, 03:32 AM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
I'm doing a lot of thinking/planning right now for my Subaru swap. That engine is capable of poutting out 260-280 HP stock. The single turbo version is very similar to the WRX engine and puts out 220 or so. Currently thats the engine I'm looking at using.
All of these are JDM (Japanese Domestic Market) engines and as such are not smog legal here. Which is great because they are cheap! I went to a place today to look at engines and you can get the single turbo engine for $650, $950 for the twin turbo, or $1250 for the Japanese WRX engine. The downside is that they typically don't come with an ECU or wiring so you have to start from the ground up. http://www.nippon-motors.com For the twin turbo engine there's a lot to do. Fiid, a user here is doing a twin turbo installation and his thread is interesting reading. He ran into problems with the starter motor interfering with the second turbo, and it looks like the exhaust construction will be tricky since the turbos are sequential. As far as I know, KEP has adapter plates/flywheel combos for most of the Subaru engines. I figure that to do a conversion like this, you need to figure maybe $2000 to $4000 depending on how you do it. I believe that a large part of the cost/work will be in the engine management system and wiring. This place: http://www.outbackmotors.com/ has some nice motors that put out a lot of power. Also they have some good resources for wiring harnesses and engine management systems. -Tony |
scotty914 |
Mar 27 2005, 09:49 AM
i would bet you could use a wrx harness and brain. as long as the maf or map sensor, are right for the brain, you might need to change things like the tps. also the sensors for cam and crank probably would work. so the harness and brain are easy to get but trouble shooting the few sensors that "might" need to change would be installed on the motor already, so they just would be replaced with new ones. fiid is having a problem with the TT due to the way they are controlled. they use a electricly controlled vacumn valve, if i understood what he told me. edit: if you want more hp than a NA will get ya go 3.3 svx its 240 hp stock or a h6 3.0 ( the new 6 cylinder ) This post has been edited by scott thacher: Mar 27 2005, 09:51 AM |
mrihop |
Mar 27 2005, 11:25 AM
Member Group: Members Posts: 265 Joined: 6-November 04 From: Pahrump, NV Member No.: 3,068 Region Association: None |
That's a good engine choice for a 914. Relatively low torque, so the stock tranny will hold up, and peaky powerband making the stock gear ratios good.
Lo-Fi Version | Time is now: 1st June 2024 - 02:22 PM |
