Are there any differences between 70–76 suspension parts ? |
Theclassiccarcoroner |
Apr 9 2016, 07:49 PM
Newbie Group: Members Posts: 15 Joined: 26-May 14 From: Alpharetta Georgia Member No.: 17,403 Region Association: None |
Can anyone tell me if there any differences between 70–76 suspension parts? Same offset?
I have a 74 914 non-rolling shell and I hoping to put on all of the suspension from a 1971 model 914. Is this gonna work? |
PancakePorsche |
Apr 10 2016, 12:38 AM
Member Group: Members Posts: 236 Joined: 29-July 11 From: Southern California Member No.: 13,373 Region Association: None |
Same geometry and widths. Front struts may be different in the lower ball joint area. Early cars may have pinch bolt and late cars (73+) for sure have wedge pin bolt to secure to lower ball joint. This will not matter if you swap all the suspension parts straight across to the 74'
Only the early (non-concentric) Pedrini wheels will not fit on later concentric hubs. Only the 914-6 has wider 911 front width. |
Apr 10 2016, 06:57 AM
Same geometry and widths. Front struts may be different in the lower ball joint area. Early cars may have pinch bolt and late cars (73+) for sure have wedge pin bolt to secure to lower ball joint. This will not matter if you swap all the suspension parts straight across to the 74' Only the early (non-concentric) Pedrini wheels will not fit on later concentric hubs. Only the 914-6 has wider 911 front width. Thank you!!! |
Lo-Fi Version | Time is now: 17th May 2024 - 08:35 PM |
