WTB for GT tribute, 911s oil thermostat |
porbmw |
Apr 15 2016, 09:50 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Slowly picking away at the bits and pieces.
Need a 911s Oil thermostat 90110780101 that fitted 69-71 IF I was not such a luddite, I would post a pic.... Thanks Paul |
dug |
May 6 2016, 05:43 PM
Member Group: Members Posts: 182 Joined: 26-December 06 From: Santa Cruz, CA Member No.: 7,382 Region Association: Northern California |
@mepstein
Your setup complete with both of the flexible lines is definitely a desirable kit for an early S guy. But you should remove the console from the tank and check for corrosion around the lip hiding under the body to tank seal. That is where these have the most problems. If it is in good shape you will be able to get top dollar for the whole setup. cheers, dug |
Lo-Fi Version | Time is now: 15th May 2024 - 01:04 PM |
