3.0SC CIS in a 914, Options? Advice? |
db9146 |
Apr 15 2016, 07:19 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'm looking for information on dropping a 3.0 SC CIS-injected engine into a 914.
What's needed for the wiring? Other parts required? Impressions? What did you use for heat exchangers? Did you have to add an external oil cooler? Front mounted cooler or fan-cooled mounted elsewhere? Thanks. |
JmuRiz |
Apr 15 2016, 07:31 PM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Fitting the fuel distributor will be an issue. You'll need th rotate it 90-deg at a minimum, maybe mount the engine a bit lower too. Worst case you'll need a custom intake work (search others that have done it)
Wiring - Perry Kiehl makes a conversion harness (I believe) Heat exchangers work w/o issue. External cooler is recommended, front mount is best, but if mostly street driven an under rear trunk setup with thermostatically controlled fans will work. |
Lo-Fi Version | Time is now: 10th May 2024 - 01:18 PM |
