3.0SC CIS in a 914, Options? Advice? |
db9146 |
Apr 15 2016, 07:19 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'm looking for information on dropping a 3.0 SC CIS-injected engine into a 914.
What's needed for the wiring? Other parts required? Impressions? What did you use for heat exchangers? Did you have to add an external oil cooler? Front mounted cooler or fan-cooled mounted elsewhere? Thanks. |
Dtjaden |
Apr 15 2016, 10:34 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
I have a slowly developing project to put a 2.7 CIS engine in my 914/4. Assuming this is going into your 914-6 you will also need a an adapted flywheel. Your existing 914-6 has a 6 bolt crankshaft and the 3.0 has a 9 bolt crankshaft. Patrick has an appropriate flywheel available.
As far as an adapter wiring harness is concerned there is very little that needs to be added/changed. The CIS system is really not an electronic system which makes the adaptation simpler. In my 914/4 I am currently using Megasquirt FI and that will be my backup plan if I have problems with CIS. Darryl |
Lo-Fi Version | Time is now: 9th May 2024 - 09:27 PM |
