3.0SC CIS in a 914, Options? Advice? |
db9146 |
Apr 15 2016, 07:19 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'm looking for information on dropping a 3.0 SC CIS-injected engine into a 914.
What's needed for the wiring? Other parts required? Impressions? What did you use for heat exchangers? Did you have to add an external oil cooler? Front mounted cooler or fan-cooled mounted elsewhere? Thanks. |
patssle |
Apr 16 2016, 10:40 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
I tore the CIS off and put on Webers for my 3.0 /6 conversion. It sounds better, looks better, performs better, easier to work on, and makes the conversion itself a lot easier with fewer electronics and sensors. But your MPG goes down and fuel smell is indeed an issue. I don't care about MPG but sometimes the fuel smell is annoying. Regrets? None.
Lo-Fi Version | Time is now: 10th May 2024 - 04:10 AM |
