3.0SC CIS in a 914, Options? Advice? |
db9146 |
Apr 15 2016, 07:19 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'm looking for information on dropping a 3.0 SC CIS-injected engine into a 914.
What's needed for the wiring? Other parts required? Impressions? What did you use for heat exchangers? Did you have to add an external oil cooler? Front mounted cooler or fan-cooled mounted elsewhere? Thanks. |
0396 |
Apr 22 2016, 05:07 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Based on my small brain, anything over a 2.7 should get an oil cooler....unless you happen to live in Alaska. As for the carbs, Paul Abbott in N Cal can rebuild the webbers for approximately $2700 - $3000, especially if the shafts need work.
I would dump a 3.2 and drive away with a Big Smile. |
Lo-Fi Version | Time is now: 10th May 2024 - 04:35 AM |
