3.0SC CIS in a 914, Options? Advice? |
db9146 |
Apr 15 2016, 07:19 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'm looking for information on dropping a 3.0 SC CIS-injected engine into a 914.
What's needed for the wiring? Other parts required? Impressions? What did you use for heat exchangers? Did you have to add an external oil cooler? Front mounted cooler or fan-cooled mounted elsewhere? Thanks. |
Justinp71 |
Apr 22 2016, 06:04 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
As for the oil cooler, if you are going to track it you will need real good cooling. The factory GT style setrab cooler mounted up front along with the engine mounted one kept me around 180-190f on the street even on the hot 100f days in sac. On the track I'd get up to 240f in a 20 min drive session.
Lo-Fi Version | Time is now: 10th May 2024 - 03:32 PM |
