3.0SC CIS in a 914, Options? Advice? |
db9146 |
Apr 15 2016, 07:19 PM
Senior Member Group: Members Posts: 953 Joined: 21-December 04 From: Atlanta, GA Member No.: 3,315 Region Association: None |
I'm looking for information on dropping a 3.0 SC CIS-injected engine into a 914.
What's needed for the wiring? Other parts required? Impressions? What did you use for heat exchangers? Did you have to add an external oil cooler? Front mounted cooler or fan-cooled mounted elsewhere? Thanks. |
EdwardBlume |
Apr 29 2016, 01:15 PM
I'm kind of having the same issue. I want more than a 2.4 T, but don't want to cut the car....
Justinp71 |
Apr 29 2016, 02:12 PM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
I'm kind of having the same issue. I want more than a 2.4 T, but don't want to cut the car.... If your not going to track it I think an oil cooler below the rear trunk would work. Jeff also states his 3.0 didn't need an external oil cooler, I believe that as mine only needed it for the track. |
Lo-Fi Version | Time is now: 9th May 2024 - 06:20 PM |
