914/6 Dash Questions |
Biggles |
Apr 16 2016, 09:48 AM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
Hi All,
my car is missing its chrome strip to the bottom of the dash (as shown in the pic). Is this a separate piece you can buy (can't see it in the PET catalogue) and how does it attach ? Also, the area under the bottom of the steering column cover doesn't look right - any thoughts ? I know there should be the two fillet pieces that go either side of the steering column which I need to get. Thanks Chris. Attached thumbnail(s) |
Gustl |
Apr 16 2016, 09:58 AM
914 enthusiast & historian Group: Members Posts: 11,507 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
there is no such chrome strip ...
not sure about the other thing (IMG:style_emoticons/default/idea.gif) |
sixnotfour |
Apr 16 2016, 10:20 AM
914 Wizard Group: Members Posts: 10,432 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
you are missing the eyebrows that go on the right and left of the plastic shroud..
also your lower shroud half is a 911 piece also It appears you may not have the tin backing pieces that the basket weave gets glued to that would close the gap And yes you are missing the chrome strip...all 70-71914s have it Attached image(s) |
Not sure if the /6 cars had the chrome strip there, my '70 /4 has it. It's glued on ...
(IMG:style_emoticons/default/smile.gif) |
fixer34 |
Apr 16 2016, 06:10 PM
Senior Member Group: Members Posts: 1,085 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest |
Not sure if the /6 cars had the chrome strip there, my '70 /4 has it. It's glued on ... (IMG:style_emoticons/default/smile.gif) March '70 build /6, mine has it right below the basket weave |
Cairo94507 |
Apr 16 2016, 07:58 PM
Michael Group: Members Posts: 9,774 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Biggles |
Apr 17 2016, 08:22 AM
Thanks for your responses guys.
So the chrome strip is stuck on - to what exactly, and does it have a part number ? I couldn't see it in the PET catalogue. Can anyone provide pics of below the steering column with and without the dash material ? Thanks. Chris. |
iankarr |
Apr 17 2016, 09:11 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,474 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
On my 73/2.0, the chrome strip is part of the lower dash knee pad. I assume it's the same on sixes...
Apr 17 2016, 10:43 AM
So the chrome strip is stuck on - to what exactly It's glued to the back of the lower knee pad. (IMG:style_emoticons/default/smile.gif) |
Biggles |
Apr 18 2016, 09:45 AM
Cheers. Does anyone know if the chrome strip still available?
Any pics out there of undr the steering column without the dash material? Thanks Chris |
Apr 18 2016, 11:00 AM
Does anyone know if the chrome strip still available? Porsche would know. Do you have a dealer close-by? (IMG:style_emoticons/default/idea.gif) |
porbmw |
Apr 18 2016, 11:33 AM
Senior Member Group: Members Posts: 811 Joined: 10-September 08 From: Vancouver, B.C. Member No.: 9,534 Region Association: None |
Do a WTB (Want to buy) here on theworld
These are not that hard to find...were pretty safe from damage until a car was parted out. I am sure that I have one, but it woiuld take me weeks to find it. Bruce, or someone else, is sure to help you out. |
porbmw |
Apr 18 2016, 11:36 AM
I should have added.....
I think that you need to make sure that you get a strip from an early car (ie..before sometime around mid 72ish???)...anyway, a car that did not have the side fresh air vents that appeared in later cars...otherwise your strip may be too short (the vents took up space on the dash) |
pete000 |
Apr 18 2016, 01:52 PM
Mine was also missing. Took a while but thanks to this board I was able to source a early lower pad with chrome deco strip.
As with most early parts they are starting to dry up. |
Biggles |
Apr 18 2016, 03:07 PM
thanks guys. will try and source one in UK or Europe as i guess shipping will be a bomb.
Lo-Fi Version | Time is now: 21st May 2024 - 10:27 AM |
