Biggles
Apr 16 2016, 09:48 AM
Hi All,
my car is missing its chrome strip to the bottom of the dash (as shown in the pic). Is this a separate piece you can buy (can't see it in the PET catalogue) and how does it attach ?
Also, the area under the bottom of the steering column cover doesn't look right - any thoughts ? I know there should be the two fillet pieces that go either side of the steering column which I need to get.
Thanks
Chris.
Gustl
Apr 16 2016, 09:58 AM
there is no such chrome strip ...
not sure about the other thing
sixnotfour
Apr 16 2016, 10:20 AM
you are missing the eyebrows that go on the right and left of the plastic shroud..
also your lower shroud half is a 911 piece
also It appears you may not have the tin backing pieces that the basket weave gets glued to that would close the gap
And yes you are missing the chrome strip...all 70-71914s have it
Not sure if the /6 cars had the chrome strip there, my '70 /4 has it. It's glued on ...
fixer34
Apr 16 2016, 06:10 PM
QUOTE(SirAndy @ Apr 16 2016, 11:20 AM)
March '70 build /6, mine has it right below the basket weave
Cairo94507
Apr 16 2016, 07:58 PM
Click to view attachment So here is a picture of my dash with the chrome strip. '71 Six.
Biggles
Apr 17 2016, 08:22 AM
Thanks for your responses guys.
So the chrome strip is stuck on - to what exactly, and does it have a part number ? I couldn't see it in the PET catalogue.
Can anyone provide pics of below the steering column with and without the dash material ?
Thanks.
Chris.
QUOTE(Cairo94507 @ Apr 17 2016, 02:58 AM)
iankarr
Apr 17 2016, 09:11 AM
On my 73/2.0, the chrome strip is part of the lower dash knee pad. I assume it's the same on sixes...
Apr 17 2016, 10:43 AM
QUOTE(Biggles @ Apr 17 2016, 07:22 AM)
It's glued to the back of the lower knee pad.
Biggles
Apr 18 2016, 09:45 AM
Cheers. Does anyone know if the chrome strip still available?
Any pics out there of undr the steering column without the dash material?
Thanks
Chris
Apr 18 2016, 11:00 AM
QUOTE(Biggles @ Apr 18 2016, 08:45 AM)
Porsche would know. Do you have a dealer close-by?
porbmw
Apr 18 2016, 11:33 AM
Do a WTB (Want to buy) here on theworld
These are not that hard to find...were pretty safe from damage until a car was parted out.
I am sure that I have one, but it woiuld take me weeks to find it. Bruce, or someone else, is sure to help you out.
porbmw
Apr 18 2016, 11:36 AM
I should have added.....
I think that you need to make sure that you get a strip from an early car (ie..before sometime around mid 72ish???)...anyway, a car that did not have the side fresh air vents that appeared in later cars...otherwise your strip may be too short (the vents took up space on the dash)
pete000
Apr 18 2016, 01:52 PM
Mine was also missing. Took a while but thanks to this board I was able to source a early lower pad with chrome deco strip.
As with most early parts they are starting to dry up.
Biggles
Apr 18 2016, 03:07 PM
thanks guys. will try and source one in UK or Europe as i guess shipping will be a bomb.
