Add a washer under the pivot ball?, Flywheel resurfaced only one time |
Amphicar770 |
Apr 20 2016, 10:35 PM
Senior Member Group: Members Posts: 1,195 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
You guys are getting too crazy with the washers. I've never needed more than one washer 1mm thick. By that point the disc is hitting the ground down bolts. The other risk you are taking is pulling the threads out of the case, there's not a whole lot of meat in this area. Thread repair is a trans tear down IIRC. Is that a 1mm washer in addition to the one already there from the factory? |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:57 AM |
