lloyd mats - did i do something wrong? |
johnpierre |
Apr 16 2016, 06:28 PM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hey everyone
these just came and im very excited (was very excited), but for one the drivers side mat has holes in it and first of all they are not in the correct position to work even if i wanted to use them and two why would i want to use them and lastly it they were in the right postion and i wanted to use them they wouldn't work b/c they are the wrong diameter and there is not give to accept the metal stays on the floor. also the passanger mat is cut to fit the tunnel it has a slight tapper to it and the driver side mat does not so it does not completely fit in the way i think it should. did i order these in correctly??? WTF (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
JmuRiz |
Apr 16 2016, 06:32 PM
914 Guru Group: Members Posts: 5,429 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Same with mine 15 years ago...I think the holes are just in a random spot.
johnpierre |
Apr 16 2016, 07:10 PM
Mikey914 |
Apr 17 2016, 06:39 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Think about this. THEY Do NOT Have the pedal slits at the top and the pins on the floor are only 1/4" long. You can't use both your carpet (that covers your pedal area, and the mat. Not with the holes engaged. We will be making front mats only and selling them for less than the Loyd mats. Return them and use your money to get a correctly fitted mat set.
I will be posting a GB soon. |
djway |
Apr 19 2016, 02:42 AM
Senior Member Group: Members Posts: 787 Joined: 16-October 15 From: Riverside Member No.: 19,266 Region Association: Southern California |
Years ago (late 80's) I purchased a carpet set that was a super plush black and had a VERY thick fluffy jute on the back. It was beautiful and quieted things down a bit. I can't be positive but I purchased a lot of parts from a company called "Beverly Hills Motoring Accessories."
Lo-Fi Version | Time is now: 21st May 2024 - 04:04 PM |
