Uhh-Ohh…., My Ongoing 914 Build Adventures.... |
Aug 18 2017, 05:52 AM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
9.5x710 or 10x710 should be correct. Did you move any shims between the pulley halves yet? (IMG:style_emoticons/default/agree.gif) Great progress! Fairly sure my 2.4 engine has or rather had 3 or 4 shims (have to admit I haven't done the last 2 services / alternator had to be replaced in that time frame) I do clearly remember the 1st time I did the belt, and it's amazing how much of a difference even adding or removing a single shim makes. I had to go out and buy some more the 1st time I did this job and also keep some in a packet tucked into the tool kit The pulley should have 6 shims. Adjustment is just moving the shims in front or between the pulley halves but never removing them completely. Six shims,not for the early motors 2 to 3 as far as I know but this a later motor so that may explain it? Even 3.2's use 6 shims. |
76-914 |
Aug 18 2017, 08:32 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Larmo63 |
Aug 18 2017, 03:23 PM
Larmo63 |
Aug 18 2017, 03:24 PM
euro911 |
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,848 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Larmo63 |
Aug 18 2017, 03:30 PM
Still a few things to order and a lot to hook up and check, double check, & triple check.
drem914 |
Aug 18 2017, 03:35 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Looks great. Like the engine color. Glad you kept going.
914_7T3 |
Aug 18 2017, 03:43 PM
Please forgive me, I'm new to all of this! Group: Members Posts: 1,847 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California |
Coondog |
Aug 18 2017, 04:04 PM
Advanced Member Group: Members Posts: 2,089 Joined: 24-September 15 From: Apple Valley Calif Member No.: 19,195 Region Association: Southern California |
ndfrigi |
Aug 18 2017, 04:23 PM
Steve |
Aug 18 2017, 04:28 PM
914 Guru Group: Members Posts: 5,571 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Aug 18 2017, 04:42 PM
All right! The first 90% is done!
Now on to the second 90%, and after that you'll only have 90% to go... --DD |
914dave |
Aug 18 2017, 05:06 PM
914 Addict Group: Members Posts: 700 Joined: 19-October 03 From: Willow Grove Pa. Member No.: 1,262 Region Association: North East States |
Congratulations! Now get that thing sorted.
bigkensteele |
Aug 18 2017, 06:07 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
By the way, when we had the heads off, we measured the pistons and they are 84mm. That means this engine is really a 2.4. We think the cams will give us milder "S" type performance numbers, along with the porting work we just did. Oh, and also by the way, I was told the engine was built to a 2.7 spec and I bought it as such................ Oh well. I think it will be a fun car, nonetheless. Are your carbs setup for a 2.4 or 2.7? Looks like your main jets might need to be changed out. https://members.rennlist.com/webercarbs/Web...et_Settings.htm |
Larmo63 |
Aug 18 2017, 06:24 PM
Yes, set up for 2.4 S spec.....!
Larmo63 |
Aug 18 2017, 06:34 PM
Lucky9146 |
Aug 18 2017, 07:11 PM
Always Wanted A Bigger Go Cart Group: Members Posts: 1,607 Joined: 22-September 14 From: Poway California Member No.: 17,942 Region Association: Southern California |
I remembered that the day the /4 blew up, we did the corner balance and stance on the car. I can't believe how low it is, it's been a long time since I've seen it with a motor in it (or that it's been on jack stands). The stance is pretty solid. If it is any consolation I have never seen mine with a motor in it. Bought it that way. (IMG:style_emoticons/default/sad.gif) Yours is looking really good with motor in place and your making great progress. (IMG:style_emoticons/default/smilie_pokal.gif) Hope to catch up! |
bigkensteele |
Aug 18 2017, 07:14 PM
76-914 |
Aug 18 2017, 09:14 PM
I remembered that the day the /4 blew up, we did a nice corner balance/stance on the car and drove it home in a "spirited" way. I can't believe how low it is, it's been a long time since I've seen it with a motor in it (or that it's been on jack stands). The stance is pretty solid. (IMG:style_emoticons/default/poke.gif) Anyone with Tool Box's that large should have finished 9 mo's ago. (IMG:style_emoticons/default/happy11.gif) |
euro911 |
Aug 18 2017, 09:55 PM
Lo-Fi Version | Time is now: 4th May 2024 - 10:23 AM |
