Does rust sleep?, Ziebart |
Gunn1 |
Apr 17 2016, 04:28 AM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
SixerJ |
Apr 17 2016, 04:42 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
No it doesn't, but you might just be correct with this rust proofing product
In my youth I was into Triumph Spitfires. They had rubbish paint and even worse rust proofing. In short succession I owned two Spitfires, one was paper thin swiss cheese in all the structural areas, the other had Zebart proofing done by the dealer from birth. Virtually no rust in the 2nd car even though they rolled off the production line just months apart / similar mileage The only downside was the fact the car had little black plastic plugs covering up the holes where they drilled to insert the spray wand. I seem to remember they were a pig to get out and you wrecked them on removal / had to replace with flat blind rubber plugs Fingers crossed that it has saved your car from the tin worm |
Gunn1 |
Apr 17 2016, 05:27 AM
No it doesn't, but you might just be correct with this rust proofing product In my youth I was into Triumph Spitfires. They had rubbish paint and even worse rust proofing. In short succession I owned two Spitfires, one was paper thin swiss cheese in all the structural areas, the other had Zebart proofing done by the dealer from birth. Virtually no rust in the 2nd car even though they rolled off the production line just months apart / similar mileage The only downside was the fact the car had little black plastic plugs covering up the holes where they drilled to insert the spray wand. I seem to remember they were a pig to get out and you wrecked them on removal / had to replace with flat blind rubber plugs Fingers crossed that it has saved your car from the tin worm The plugs on this car are yellow you see one in the upper part of the door |
sb914 |
Apr 17 2016, 05:41 AM
Surf Guru Group: Members Posts: 4,305 Joined: 25-November 12 From: Brookings,Oregon Member No.: 15,191 Region Association: Southern California |
Gunn1 |
Apr 17 2016, 05:53 AM
Gunn1 |
Apr 17 2016, 07:34 AM
boxsterfan |
Apr 17 2016, 05:03 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Might have helped but probably not. Has the car been sitting outside for years?
Let's see the longs and the hell hole. |
Gunn1 |
Apr 17 2016, 05:20 PM
Might have helped but probably not. Has the car been sitting outside for years? Let's see the longs and the hell hole. I will get the Rockers off and take some more photos of the longs next weekend. Had to pick up another 914 today! Attached thumbnail(s) |
Gunn1 |
Apr 17 2016, 05:24 PM
Gunn1 |
Apr 17 2016, 05:30 PM
Gunn1 |
Apr 17 2016, 05:39 PM
Gunn1 |
Apr 17 2016, 05:41 PM
boxsterfan |
Apr 17 2016, 06:50 PM
In my opinion, there is quite a bit of rust there although the car is not folding in half. Under what conditions was it stored?
Gunn1 |
Apr 17 2016, 07:47 PM
In my opinion, there is quite a bit of rust there although the car is not folding in half. Under what conditions was it stored? Car was stored inside. Sure there is some rust scale but the steel is solid everywhere I have poked around. It might be something to turn your nose up about coming from California, but I think it is a great find There are no rust holes in the floor boards, inner fender wells, trailing arms or councils, the front bulkhead including under the spare have zero rust. There are no holes on the inner longs.It has the factory paint which means there has been no bodywork done on the car, which is phenomenal for a 42 year old automobile. I have looked at many (20) Midwestern 914s and this is the cleanest I have yet to find. And that is why I purchased it. Guess it's just a difference of opinion, but I think the rust treatment saved the car (IMG:style_emoticons/default/aktion035.gif) |
veekry9 |
Apr 17 2016, 08:13 PM
OldMember Group: Retired Members Posts: 3,068 Joined: 17-June 13 From: TO Member No.: 16,025 Region Association: Canada |
Is good.
(IMG:style_emoticons/default/smile.gif) Ziebart did good business here in the TO,the salt slush the most aggressive. A waxy,medium viscosity spray with good wicking into seams,saved many a rocker. / |
Gunn1 |
Apr 18 2016, 09:52 AM
Is good. (IMG:style_emoticons/default/smile.gif) Ziebart did good business here in the TO,the salt slush the most aggressive. A waxy,medium viscosity spray with good wicking into seams,saved many a rocker. / 10-4, we have much the same crud here in Mn. That salt brine they put down was death for many automobiles. It was worse for anything like a 914 with a unibody that didn't have today's "factory" zinc and other coatings/trearments where the car is actually dipped in the treatment. I worked on many, many rusted out vehicles in my day and can say the early unibody car was the vehicle that always got the worst of "Rusty" (IMG:style_emoticons/default/smash.gif) |
Elliot Cannon |
Apr 18 2016, 12:17 PM
Rust NEVER sleeps. It is an evil, insidious, living thing. It is to be challenged, fought and defeated at every opportunity. (IMG:style_emoticons/default/sawzall-smiley.gif) (IMG:style_emoticons/default/smash.gif) (IMG:style_emoticons/default/welder.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 09:08 AM |
