a arm removal, im puzzled. |
opera guy |
Mar 30 2005, 05:46 PM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
how the heck do you rremove the a arm? i wanna replace the bushings.
ps in the process of installing tie rods, ball joints (removed), just waiting on how the a arm comes off. |
skline |
Mar 30 2005, 05:48 PM
That is all too easy. Just remove the bolts in the front and then the rear bolts and it drops right out. Are you really having a problem with it??
opera guy |
Mar 30 2005, 05:53 PM
bolt 30 and 17? (those arent removed yet)
30 is stuck in there, will take some elbow grease Attached image(s) |
Jeroen |
Mar 30 2005, 05:54 PM
if you already have the tie-rods and balljoints loose, then it's a walk in the park (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
unbolt the torsionbar adjuster bolt (all the way out) and take off the adjuster cap next to the adjuster bolt, there's a bolt that holds the a-arm to the x-member, take it out upfront, there's a protective cover over the end of the a-arm it's bolted to the chassis with a single allen bolt, take it off then there's 2 bolts that mount the front of the a-arm to the chassis, remove them (have the a-arm supported) now you can pull the a-arm from the x-member (forward motion) |
Jeroen |
Mar 30 2005, 05:57 PM
liquid wrench... or even better: impact wrench (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
opera guy |
Mar 30 2005, 06:20 PM
ok ok, you guys rock. i got them both out, now, how do i take the "stuff" off to replace the bushings? lol
datapace |
Mar 30 2005, 06:25 PM
Member Group: Members Posts: 133 Joined: 19-January 04 From: Atlanta, GA Member No.: 1,579 Region Association: South East States |
A MAPP gas torch works the best. Don't cook the bushings, just until apply flame you see light grey smoke, then insert a chopstick (er, screwdriver) in the bolt holes of the mounts and just twist right off. Then you can use a utility knife if you need to or just slip the old rubber bushing off of the arm itself.
-bryan |
Eric_Shea |
Mar 30 2005, 06:26 PM
Chop Sticks (IMG:http://www.914world.com/bbs2/html/emoticons/lol2.gif)
Eric_Shea |
Mar 30 2005, 06:28 PM
OK... I'll be serious.
Heat. Use a torch until you see a "whisp" of smoke. Then take a big screwdriver and start turning them and pulling them off. Once the outer covers are off, cut with a utility knife and remove the remainder of the bushing. |
Eric_Shea |
(or what Bryan said) (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Series9 |
Mar 30 2005, 06:31 PM
Crap. 3 minutes late on that one. (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) |
Series9 |
Mar 30 2005, 06:33 PM
here:
opera guy |
Mar 30 2005, 06:54 PM
LMFAO!!!!!!!! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) |
Mar 30 2005, 08:56 PM
914 Idiot Group: Members Posts: 14,983 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California |
I think we need to get a chopstick smiley added to the list of clickable ones...
--DD |
mike_the_man |
Mar 31 2005, 09:26 AM
I like stuff! Group: Members Posts: 1,338 Joined: 11-June 03 From: Regina, Saskatchewan, Canada Member No.: 809 |
ROFLMAO!!! Man, you guys kill me. I don't think anybody ever forgets anything here. If I ever screw up, remind me not to post it! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Lo-Fi Version | Time is now: 9th May 2024 - 10:09 PM |
