914-6 oil tanks and filler necks |
mb911 |
Apr 18 2016, 02:15 PM
914 Guru Group: Members Posts: 6,827 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
As it is well documented on here I have completed reproduction aluminum oil tanks for 914-6s/ conversions. Tanks are available from PMB performance or directly from me.. They are internally baffled and have 22mm fittings so you can use multiple adapters for oil lines.
Tanks are $600 plus shipping and come powder coated flat or gloss black Oil filler necks are $135 plus shipping Please feel free to call with any questions Ben M&b specialties plc 262-364-7426 Oil filter consoles coming soon. |
shoguneagle |
Jul 2 2016, 07:33 PM
shoguneagle Group: Members Posts: 1,180 Joined: 3-January 03 From: CA, OR, AZ (CAZOR); New Mexico Member No.: 84 Region Association: Northern California |
How may quarts does it hold? Original 9 or more? Can you do direct larger threaded openings to match the 16AN and 12AN?
Like what you are doing; looks great. Steve |
mb911 |
Jul 6 2016, 02:18 PM
How may quarts does it hold? Original 9 or more? Can you do direct larger threaded openings to match the 16AN and 12AN? Like what you are doing; looks great. Steve They are slightly larger about 9.5. I have welded direct -12 and -16 fittings on for other folks all in what you want. The limiting factor is that no matter what the scavenge side of the engine is -12 so Going larger doesn't help on that side.. I hope That helps |
Lo-Fi Version | Time is now: 6th May 2024 - 07:43 AM |
