Targa top corner repair? |
Menmojo |
Apr 18 2016, 04:19 PM
Porsche addict Group: Members Posts: 49 Joined: 7-July 15 From: Midwest Member No.: 18,929 Region Association: None |
I'm planning on refinishing the targa top on my 75 914. One of the front corners is broken off and I'm looking for advice on how to repair it. The previous owner painted it the same color as the body and I'm not happy with the way it looks. My plan is to attempt to repair the front corner, sand the top flat then have it sprayed in a satin black finish. I know I could attempt to find a new top but thought I would give it a shot to repair the one I have first.
Any advice on how to attempt to fix the corner? |
Tom_T |
Apr 18 2016, 05:47 PM
It's a 2-part fiberglass resin, so a FG repair kit from the local Home Despot etc. would work, although you'll probably need to cut some FG into short 1/16"-1/8" strands to mix in for strength in that corner.
You may need to make a cardboard or wood form to hold the resin til it sets, but you need a release agent on it to keep it from sticking to the form (check the resin/hardener tech info for what they recco for release agent with their particular formulation). You'll probably want to use the Wurth under body Shutx for the pebble texture to match the original look, but practice sprays on some cardboard before trying the roof, then spray your satin or semi-matte black over it. There are some threads in O&H on the techniques to finish the tops, or look at rockers & valances - which are the same finish technique. Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
Cuda911 |
Apr 18 2016, 05:49 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
A pic would help, but I would think that any fiberglass kit (cloth and resin) would work just fine. If it's really small, any of those plastic mender putties should be fine.
Menmojo |
Apr 18 2016, 06:21 PM
Cuda911 |
Apr 18 2016, 11:14 PM
I think I'd try a two-part plastic/epoxy putty for that corner. Be sure to clean of the paint first. There are many brands, some that set up rock hard and are extremely durable.
Also, give 914Rubber a call and get that funky rubber replaced. (IMG:style_emoticons/default/smile.gif) |
era vulgaris |
Apr 19 2016, 08:05 AM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
Wow, what color is your car? In that pic it looks like an old VW color L398 Pacific Blue. And with a white interior??? More pics of this car please! (IMG:style_emoticons/default/drooley.gif)
Menmojo |
Apr 19 2016, 07:32 PM
Here are a couple photos. I'm not sure exactly what color the car is. I bought this 914 about a year ago. I'm an avid porsche enthusiast and PCA racer. I stumbled on this car on Craigslist. I wasn't even seriously looking for a 914 but when I checked it out it was an absolutely rust free car. It also has the original engine with fuel injection intact. Although it needs some attention I took it on as a fun project since it was rust free. Recently I gutted and installed an entirely new interior thanks to Mickey914 at 914 rubber. The car originally did have a white interior so I decided to restore it as such. If you have a guess on what color it is let me know. It's close to Olympic blue but a shade off. It is a brighter blue than Olympic.
Sooner or later I'll post some better photos. Thanks to 914 rubber the interior gets a lot of positive comments. |
era vulgaris |
Apr 23 2016, 07:32 AM
Ah ok, yeah it's definitely blue. That closeup photo it looked like it had some green in it. Looks great though and that interior is gorgeous! I'd be terrified of it. It would probably end up covered in grease and oil smudges if it were mine. (IMG:style_emoticons/default/biggrin.gif)
76-914 |
Apr 23 2016, 08:28 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'd be damn surprised if one could just scab on that piece without it separating soon thereafter! Yes you can add strands of glass or micro balloons to make a stronger slurry but the attach area itself will be small and stressed. If it were me, and it's not (IMG:style_emoticons/default/biggrin.gif) , I would do a scarf joint and take it back at least 4". (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 21st May 2024 - 04:57 AM |
