what is this little dude? |
Gunn1 |
Apr 19 2016, 06:22 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
bandjoey |
Apr 19 2016, 06:35 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
I think it's to stop spark plug static on older radios. Forgotten what it's called since I haven't seen something like it in years.
MarkV |
Apr 19 2016, 07:10 PM
.47 microfarad capacitor that is used to shunt any AC voltage that is on the DC voltage to ground. This is used to suppress radio interference from the ignition system on the coil?
Gunn1 |
Apr 19 2016, 07:21 PM
.47 microfarad capacitor that is used to shunt any AC voltage that is on the DC voltage to ground. This is used to suppress radio interference from the ignition system on the coil? Thanks for your help. Am I correct to think this shunt is no longer needed with newer radios? |
bandjoey |
Apr 19 2016, 09:58 PM
Only if you use a period radio
Lo-Fi Version | Time is now: 21st May 2024 - 11:19 AM |
