Brake / clutch / trans cable routing |
Amphicar770 |
Apr 20 2016, 04:14 PM
Senior Member Group: Members Posts: 1,191 Joined: 20-April 10 From: PA, USA Member No.: 11,639 Region Association: MidAtlantic Region |
Hi All,
Hope this question makes sense. Before putting engine back in. Do the brake cables, clutch cable, etc. sit above or below the engine mounting bar? There is a hole in the bar that looks like cables can pass through. Which one(s) route through this hole? Thanks, Mike |
76-914 |
Apr 20 2016, 04:40 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,504 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
The shift rod
Apr 20 2016, 04:54 PM
Only on the side-shift cars.
There is a hole on the right side of the bar as well, and one of the cables goes through it. I want to say the speedo cable, but I'm not at all sure. --DD |
saigon71 |
Apr 21 2016, 06:12 AM
Senior Member Group: Members Posts: 1,999 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
Hi All, Hope this question makes sense. Before putting engine back in. Do the brake cables, clutch cable, etc. sit above or below the engine mounting bar? There is a hole in the bar that looks like cables can pass through. Which one(s) route through this hole? Thanks, Mike The clutch cable runs through the small hole in the engine mount bar on the passenger side. There is a protective sheath around it that is a tight fit in the hole. I run my odometer, throttle cable and drivers side e-brake cable above the engine bar. The routing of the passenger side e-brake cable makes it difficult to run above the bar without putting pressure on it...so I ran this one outside the engine mount bar...but zip-tied to the bar on the side. The engine mount bar is one of the low points of the car. Keeping the cables above it is a good idea. |
Lo-Fi Version | Time is now: 21st May 2024 - 11:44 AM |
