2 Pages V < 1 2
> newbie on forum, just bought 73 2.0 showing off!
Dominic
post Apr 23 2016, 10:17 AM
Post #21
Dominic
Welcome to the 914 family! (IMG:style_emoticons/default/beerchug.gif) There a bunch of owner enthusiasts here in Nor Cal.
Tom_T
post Apr 23 2016, 10:27 AM
Post #22
TMI....
QUOTE(iwanta914-6 @ Apr 23 2016, 12:06 AM) *
Wasn't this one advertised for sale here? She's a beauty and that kind of beauty doesn't come cheap. nice buy
Yes, it was DanK's car & advertised on here, CL, etc.
Tom
Tom_T
post Apr 23 2016, 10:39 AM
Post #23
TMI....
QUOTE(frankieshooz @ Apr 22 2016, 11:14 PM) *
I do believe the A/C was dealer installed and I am contemplating removing the whole system as it's just fugly!!!! it does open up a can of worms: replacing the hole it would leave in the trunk, block off plates etc.. Anyway this will not be any trailer queen as it will be sharing driving duties with my beloved Mazda 94 FD3S R2....
comments, advice, help appreciated...if any of you experts are in or near marin county let me know so we can get together for some 914 education...
Frankie, I'd advise not removing the AC - since yours IIRC is the original dealer installed AC - & you're in North Bay Area where it gets hot some, & in CA/Southwest USA in general - it's a nice feature. Back then Porsche didn't really install factory air in 914s or 911s, so the dealers did them with either a DPD or VPC system, with approval from Porsche NA (same with many accessories & options, including radios for most 914s being from dealers).
I've always wished that mine had AC - being in SoCal, especially back when it was my DD & I'd get to work meetings with my back soaked with sweat & have to leave my suit or sport coat on all the time to hide it! (IMG:style_emoticons/default/dry.gif)
What you should do - if Dan didn't already - is to convert it to the R134 with the newer rotary type compressor which are more efficient & only rob 1-3 HP, vs. the old school York one robbing 5-8 HP. IIRC AutoAtlanta has the parts, & RetroAir (see ads in "Panorama"), & maybe some local Bay Area vintage Porsche AC shops can set you up with it, or install the proper compressor from the other sources.
Enjoy your new FUN go-cart ride! (IMG:style_emoticons/default/driving.gif)
Cheers! (IMG:style_emoticons/default/beerchug.gif)
Tom
frankiec@outrageous.net
post Apr 23 2016, 10:40 AM
Post #24
Not sure about your statement " I realize on an older Porsche that is more of a challenge than say newer Porsche cars"??? Have you ever tried to work on a newer Porsche??? I'll wrench on a 914 any day before trying to deal with the nightmare of the newer cars. Basically on a newer Porsche's you've got to it take to the dealer or a reputable shop at $125-$150 and hour. The 914 is a simple, straight ahead car and the owner, with a little motivation, (IMG:style_emoticons/default/smash.gif) can work on their own cars.
QUOTE(Cairo94507 @ Apr 23 2016, 06:03 AM) *
(IMG:style_emoticons/default/welcome.png) That is a beautiful 914. Before you embarked on any projects I would get it to a shop that knows these cars well and go over it front to rear looking for any issues that might not be apparent. Even on cars as nice as yours there might be something that was missed by a previous owner.
I would then focus on the fuel system to make sure it is up to date and 100% reliable. Stainless steel fuel lines in the tunnel and new rubber anywhere else with new clamps and filters. That includes taking a look into the fuel tank to see if it looks clean or not. Don't forget the fuel tank sock filter.
After that for me it would be electrical. I would look for anything not original. I am not a radio or alarm guy so for me if it did not come factory, it would be removed. I would want to make sure the factory harness and fuse block were all up to snuff and the correct fuses were installed. It is not unheard of for people to swap in higher rated fuses when they start blowing a particular fuse. I would clean all of the ground connections and tighten them. Check to make sure every single item on your car is fully functional. Once you are sure all the wiring is 100% good, then I would add whatever you desired so you know it is added correctly - stereo, etc.
Of course brakes are a big deal on our cars. At the minimum, unless the seller had just done it, I would flush the entire system and check all the rotors and pads. Make sure the emergency/parking brake is correctly adjusted and functional. Eric Shea at PMB performance in Utah http://www.pmbperformance.com/catalog.html is the go-to guy for all things brakes.
Actually, Eric is now doing complete restorations so he is a valuable source for anything on these cars. We are blessed to have many people here who are dedicated to maintaining and restoring our cars. Chris at Tangerine Racing who sells the SS fuel lines http://www.tangerineracing.com/about_us.htm is a terrific guy too. So many experts supporting our community and they are all available to you.
Mechanical issues are next. Make sure the suspension, engine and transaxle are in good repair. Oil leaks? I personally can't tolerate them. I realize on an older Porsche that is more of a challenge than say newer Porsche cars, but it is possible to have a 914 that does not leak. Do a leak down and compression test to make sure the motor is healthy. If the numbers are good, unless it had recently been done, I would do a valve adjustment and complete tune-up to set a base line for driving.
Lastly, comes all the cosmetics. That is more involved too. Weather seals (Mikey914 at 914rubber.com http://914rubber.com has almost anything you need in this department), any visible body rust, bumpers that are not aligned correctly, exhaust systems that are rusty, have holes in them or are leaking.
OK, I have kind of rambled on here as I have my first cup of coffee.... Sorry and best wishes on your beautiful car.
post Apr 23 2016, 11:07 AM
Post #25
Resident German
Mill Valley, CA
I used to live in Mill Valley, back in the canyon on Eldridge ...
2 Pages V < 1 2
- Lo-Fi Version Time is now: 31st October 2024 - 06:16 PM
