Euro Turn Signal Conversion Wiring |
ThinAir |
Apr 23 2016, 01:53 PM
Best friends Group: Members Posts: 2,536 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I'm putting my car back together after a repaint. Unfortunately, I didn't disassemble the front turn signals. I've got the Camp914 euro turn signal kit installed, but it's been years since I installed it and I can't find the instructions for wiring.
When I look at the wiring diagram, I see just terminals 49R (or 49L) and 58, but when I look at the lights I've got terminals marked 57, 31, and BL. And then I've got the "hot" wire for the conversion. The harness has Brown, Black/White, and Gray/Black wires. Can anyone give me a clue how to put these lights back together? |
SixerJ |
Apr 24 2016, 02:37 AM
Member Group: Members Posts: 448 Joined: 24-June 13 From: UK Member No.: 16,042 Region Association: England |
All European cars have a clear sidelight (lower section in the case of the teener) / tail light on at 1st position of the light switch, 2nd position adds in the headlights. Amber only ever functions as direction indicator
My old black ex Cali 914 had the turn signals converted when she came over by the PO and functioned this way / same as all my other cars including the 911 which has lived in the UK all its life If you have a park function, i.e. indicator stalk up or down, this lights up the left or right side light only. The 911, Audi and Landrover has this but the kids cheap Eurobox does not, so it's not universal. Not sure if 914s came with this function, my black 914 didn't if I recall correctly - Porsche saving cost on the 914 v 911? Good luck and this is a job and is something I will have to do on my six eventually |
Shivers |
Apr 11 2021, 12:24 PM
Senior Member Group: Members Posts: 2,365 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
If you have a park function, i.e. indicator stalk up or down, this lights up the left or right side light only. The 911, Audi and Landrover has this but the kids cheap Eurobox does not, so it's not universal. Not sure if 914s came with this function, my black 914 didn't if I recall correctly - Porsche saving cost on the 914 v 911? My 72' does this |
DRPHIL914 |
Apr 14 2021, 09:41 AM
Dr. Phil Group: Members Posts: 5,764 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
If you have a park function, i.e. indicator stalk up or down, this lights up the left or right side light only. The 911, Audi and Landrover has this but the kids cheap Eurobox does not, so it's not universal. Not sure if 914s came with this function, my black 914 didn't if I recall correctly - Porsche saving cost on the 914 v 911? My 72' does this is that what that is, a "park" function? i just noticed the other day, turning off the car but the lever was up so the side marker light was on, not flashing, key turned to off position. AND one other realization along this line about the flasher, i always thoght my flasher was bad or not hooked up correctly, because it didint flash when pulled BUT, by accident i was testing this due to having a short in the right front turn signal bucket with the euro conversion wiring, and accidentally i flipped the signal stalk up when the flasher was pulled out and it was flashing! SO is this normal or is it miss-wired? i have to have the lever up or down not in neutral position for the flasher to flash when pulled. |
Lo-Fi Version | Time is now: 3rd May 2024 - 05:04 AM |
