Transmission mounts for V8 with setback blocks, Type recommendations |
Gearup |
Apr 23 2016, 03:35 PM
Member Group: Members Posts: 154 Joined: 21-April 15 From: Denver Member No.: 18,660 Region Association: None |
Curious if anyone here who has a V8 conversion and has used Renegades aluminum set back blocks. I need a recommendation on a source and type/brand of transmission mount that would work well with my 283 V8 application. Thanks for any help. Trying to get this 5 year project DONE!
tomrev |
Apr 23 2016, 04:15 PM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
Curious if anyone here who has a V8 conversion and has used Renegades aluminum set back blocks. I need a recommendation on a source and type/brand of transmission mount that would work well with my 283 V8 application. Thanks for any help. Trying to get this 5 year project DONE! Yes the Renegade blocks are fine. Once you see how simple they are, you can make your own easily, if you like making things. Basically, just a chunk of 1in. by 1 1/2 in. wide Al. bar stock cut about 3 in. long. Took 20 min. to cut and drill the one's I'm using now. |
tomrev |
Apr 23 2016, 04:23 PM
This:
Attached thumbnail(s) |
Chris914n6 |
Apr 23 2016, 04:24 PM
Jackstands are my life. Group: Members Posts: 3,321 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
911 sport mounts is the usual. I think the prevailing theory is the stock mounts won't be happy with the additional weight. Or they just could have been cheaper back when I did mine (IMG:style_emoticons/default/confused24.gif)
Gearup |
Apr 23 2016, 05:48 PM
911 sport mounts is the usual. I think the prevailing theory is the stock mounts won't be happy with the additional weight. Or they just could have been cheaper back when I did mine (IMG:style_emoticons/default/confused24.gif) Thanks. To clarify my post I do already have the Renegade setbacks and appreciate the 911 Sport suggestion. I had heard this a while ago. You wouldn't happen to know a source or brand would you? Brett |
Lo-Fi Version | Time is now: 21st May 2024 - 05:50 PM |
