Throttle Body Replace / Repair |
lsintampa |
Apr 24 2016, 02:32 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 Original FI
My throttle body is a bit worn out. They are NLA so I was curious if anyone knows of another make / model that would work, and or if there are any repair / rebuild services available? Thanks, Len |
TheCabinetmaker |
Apr 24 2016, 03:23 PM
I have a couple good used ones if that would interest you.
Gunn1 |
Apr 24 2016, 03:33 PM
Senior Member Group: Members Posts: 1,021 Joined: 14-February 16 From: Minnesota Member No.: 19,670 Region Association: None |
Rob-O |
Apr 25 2016, 07:20 AM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
75 2.0 Original FI My throttle body is a bit worn out. They are NLA so I was curious if anyone knows of another make / model that would work, and or if there are any repair / rebuild services available? Thanks, Len See this thread. http://www.914world.com/bbs2/index.php?sho...amp;hl=TB+samba I just sent mine to him and it should be returned to me today. |
Rob-O |
Apr 25 2016, 07:21 AM
I have a couple good used ones if that would interest you. I am also looking for a Throttle body and the manifold for a 1975 2.0 liter if you have any that are available. Thank you Post a WTB, I'm sure there are people here who have a TB and manifold lying around. |
rhodyguy |
Apr 25 2016, 07:45 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
No doubt. You'll get multiple offers.
Rob-O |
May 2 2016, 10:49 AM
They look like this when you get them back...
MartyYeoman |
May 2 2016, 10:59 AM
Senior Member Group: Members Posts: 1,517 Joined: 19-June 03 From: San Ramon, CA Member No.: 839 Region Association: Northern California |
pete000 |
May 2 2016, 11:29 AM
Have it rebuilt, you will be happy with the results !
Rob-O |
May 2 2016, 01:54 PM
Bah, the pics were upside down the first time. I must've messed them up when I removed them and tried to reattach pics that were right side up. Attached thumbnail(s) |
May 2 2016, 05:11 PM
Custom Member Group: Members Posts: 24,564 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Cost?
914_teener |
May 2 2016, 05:34 PM
914 Guru Group: Members Posts: 5,194 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
lsintampa |
May 2 2016, 06:22 PM
Rob-O |
May 2 2016, 08:03 PM
Cost? Depends on what needs to get done and what kind of shape the TB is in. But anywhere from $275-$365 I believe. In my case it was $300. That included zinc plating of the throttle spring and associated parts. New throttle plate (butterfly). TB bore is machined (1mm larger). Re-bushed. Bead blasted body. Custom throttle stop installed. The throttle stop helps the plate from contacting the side of the TB bore. Stock, the plate rested against the bore and eventually causes wear and a sticking plate. I am going back to FI, and with the TB off the car the throttle plate felt sticky when I actuated the throttle by hand. So I figured I'd have this work done. I'm trying my best to get everything checked, rebuilt or restored. Hopefully that will make the install go a little more smoothly and I'll have a better chance of the car firing up on the first try once the FI retrofit is complete. |
nordfisch |
May 3 2016, 09:55 AM
Member Group: Members Posts: 86 Joined: 11-December 15 From: Germany Member No.: 19,451 Region Association: None |
Hi,
repair kits are available for Volvo, better quality than the original parts. Maybe a less expensive alternative... Please ask the manufacturer (link below the information provided for Volvo) for parts available for the 914: http://www.v1800.org/index.php/en/servicin...repair-kit.html regards Norbert |
May 3 2016, 10:35 AM
Cost? Depends on what needs to get done and what kind of shape the TB is in. But anywhere from $275-$365 I believe. In my case it was $300. That included zinc plating of the throttle spring and associated parts. New throttle plate (butterfly). TB bore is machined (1mm larger). Re-bushed. Bead blasted body. Custom throttle stop installed. The throttle stop helps the plate from contacting the side of the TB bore. Stock, the plate rested against the bore and eventually causes wear and a sticking plate. I am going back to FI, and with the TB off the car the throttle plate felt sticky when I actuated the throttle by hand. So I figured I'd have this work done. I'm trying my best to get everything checked, rebuilt or restored. Hopefully that will make the install go a little more smoothly and I'll have a better chance of the car firing up on the first try once the FI retrofit is complete. So' the body is bored out 1mm yet the stock throttle plate is still used, with a throttle stop to prevent it from getting stuck? |
Rob-O |
May 3 2016, 01:35 PM
No, there is a new throttle plate. I mentioned that in the post above. Although I should've mentioned that in addition to the throttle plate being new, it is also 1mm larger to make up the 1mm that was milled out of the bore. I should've taken a picture down the throat but didn't. Kinda late now, TB is on the car.
Mikey914 |
May 6 2016, 11:16 AM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My ears are burning, I looked at doing these for the 944 adding a new bushing to tighten up the intake butterfly. If there's enough interest I can look at these. As we already stock the new boards for the early and late 1.7 as well as the 2.0.
Rob-O |
May 6 2016, 11:39 AM
My ears are burning, I looked at doing these for the 944 adding a new bushing to tighten up the intake butterfly. If there's enough interest I can look at these. As we already stock the new boards for the early and late 1.7 as well as the 2.0. AND you supply the 1.8L plenum to TB gasket. Guess where I got mine... |
Lo-Fi Version | Time is now: 26th April 2024 - 04:04 AM |
