Throttle Body Replace / Repair |
lsintampa |
Apr 24 2016, 02:32 PM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
75 2.0 Original FI
My throttle body is a bit worn out. They are NLA so I was curious if anyone knows of another make / model that would work, and or if there are any repair / rebuild services available? Thanks, Len |
Rob-O |
May 2 2016, 08:03 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Cost? Depends on what needs to get done and what kind of shape the TB is in. But anywhere from $275-$365 I believe. In my case it was $300. That included zinc plating of the throttle spring and associated parts. New throttle plate (butterfly). TB bore is machined (1mm larger). Re-bushed. Bead blasted body. Custom throttle stop installed. The throttle stop helps the plate from contacting the side of the TB bore. Stock, the plate rested against the bore and eventually causes wear and a sticking plate. I am going back to FI, and with the TB off the car the throttle plate felt sticky when I actuated the throttle by hand. So I figured I'd have this work done. I'm trying my best to get everything checked, rebuilt or restored. Hopefully that will make the install go a little more smoothly and I'll have a better chance of the car firing up on the first try once the FI retrofit is complete. |
Lo-Fi Version | Time is now: 27th May 2024 - 07:25 PM |
