914/4 vs 914/6 Front Track Width, Measured from hub face to hub face |
gcrotvik |
Apr 25 2016, 10:59 AM
Member Group: Members Posts: 360 Joined: 16-December 09 From: Portland Oregon Member No.: 11,134 Region Association: Pacific Northwest |
My apologies if this topic has been discussed previously. Is the front track width, measured from the left hub face to the right hub face, the same on a 4 and a 6? If not, does someone know the differences?
Thank you, Greg |
Krieger |
Apr 25 2016, 01:33 PM
Advanced Member Group: Members Posts: 4,714 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
I think the 6 does have a wider front track. IIRC it is around 10mm on each side. So 20mm total. I just remember comparing a 4 assembly to a 6 assembly on the bench.
fasthonda |
Apr 25 2016, 02:20 PM
914 Type R Group: Members Posts: 133 Joined: 10-January 04 From: Greenville, SC Member No.: 1,544 Region Association: None |
I think the 6 does have a wider front track. IIRC it is around 10mm on each side. So 20mm total. I just remember comparing a 4 assembly to a 6 assembly on the bench. I calculated the same for my 914 with 87 Carrera front end. Front track is 20mm wider than 914-4. |
gcrotvik |
Apr 25 2016, 02:40 PM
I think the 6 does have a wider front track. IIRC it is around 10mm on each side. So 20mm total. I just remember comparing a 4 assembly to a 6 assembly on the bench. That's what I recall but I don't remember the exact difference. I'm trying to figure wheel/tire and if needed, spacer sizes. Thanks! Greg |
Lo-Fi Version | Time is now: 21st May 2024 - 10:15 AM |
