LukeD |
Member ![]() ![]() Group: Members Posts: 254 Joined: 14-November 04 From: Atascadero, CA Member No.: 3,117 Region Association: None ![]() |
I finally got my 70 1.7 FI on the road w00t! (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) When I come to a stop and press in the clutch the idle drops to almost dieing and then pops back up to 800. It has too be something simple. Do I need to clean a sensor or something? This also happened before I removed the engine.
Also, my throttle cable drags just a little. Before I pulled the engine I didn't have this problem. I have inspected the cable and it actually apears new, couldn't find any problems with it. If I un-hook it from the throttle body and mount point and have the wifey press the pedal it slides smoothly. Anyone have a picture of their engine compartment showing which side of the air cleaner bracket it routes through? I tried different ways but the only way it seems to reach is the way I have it. Come on show me those clean engine bays (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) Thanks Luke D |
LukeD |
Oh, I wanted to mention that the cars runs perfect except for that symptom. I have inspected and repaired any questionable spots on the harness while the engine was out. I have also made sure every wire is hooked up properly.
Luke D |
merrill |
Dirt Pimp ![]() ![]() Group: Members Posts: 224 Joined: 25-January 05 From: Tahoe City, Ca Member No.: 3,505 Region Association: None ![]() |
Shouldn't you show us yours first (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif)
TheCabinetmaker |
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,338 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 ![]() |
Luke, do you have an adjustment knob on your ECU? A pic of your cable route would be very helpful. I really don't wanna dismantle half my FI stuff to take a pic!!!!
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,196 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Did you check to see if the cables were not wrapped around each other up near the pedal cluster?
--DD |
Lo-Fi Version | Time is now: 5th July 2025 - 02:59 PM |
