What kind of Cylinders are these?, I bought a 914 with Nickies, but not sure what I received. |
HansJan |
Apr 28 2016, 08:03 PM
Member Group: Members Posts: 394 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
The 1972 914 I bought is supposed to have 103mm Nickies (by LN-Engineering) with JE-forged pistons.
The car caught on-fire, so I had to remove the engine. After doing so I find that the cylinders are magnetic. Nickies are made from Aluminum, so this is suspicious. Is any of you able to recognize the make of the Cylinders in the below pictures. There is one picture with some marking on it. I do not want to disassemble the engine any further then needed. I only own this car for two weeks now, but going up a very steep learning-curve. very soon I will be able to help others. But for now I'm only asking questions. Br, Hans Jan |
0396 |
Apr 28 2016, 08:09 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
Sorry to hear of your car. In regards to your question, I think you already know the answer.
rhcb914 |
Apr 28 2016, 08:11 PM
member Group: Members Posts: 358 Joined: 3-February 04 From: Boston, MA Member No.: 1,626 |
ThePaintedMan |
Apr 28 2016, 08:16 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
At this point, I'd be willing to bet the pistons aren't JE's either. But no worries. That's why we're here. I saw the video - that sucks. You got taken by the previous owner, but you're certainly not the first one. It can all be rebuilt. Of course it takes more time and $$ out of your own pocket, but we'll help you figure it all out. |
HansJan |
Apr 28 2016, 08:35 PM
Even though this is bad news, you guys are the best.
I have looked at the AA-website, but cant find the machine size for the register. If this register is bigger then 108.5mm the Nickies won't fit anymore. Anyone knows the register size for AA-cylinders 103mm? |
Valy |
Senior Member Group: Members Posts: 1,671 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
The orange silicon tells a lot about who built this engine. You don't want it there.
914Sixer |
Apr 28 2016, 08:51 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
You will have to disassemble the engine to find out what you have. If it is running good just tell everyone you have a mystery engine.
Mueller |
Apr 28 2016, 08:59 PM
Nickies are machined, those are cast cylinders, I hope you didn't pay for Nickies!
Mueller |
Apr 28 2016, 09:00 PM
rick 918-S |
Apr 28 2016, 09:05 PM
Hey nice rack! -Celette Group: Members Posts: 20,426 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
What video? What did I miss? Maybe not the engine it's supposed to be but if you had a fire you have way more on your plate now. If that engine runs good don't worry about it. Sort it out after you fed the car repaired. (IMG:style_emoticons/default/welcome.png)
ChrisFoley |
Apr 29 2016, 04:56 AM
I am Tangerine Racing Group: Members Posts: 7,910 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Those aren't 103s.
The case registers are probably unmodified. |
jdm914 |
Apr 29 2016, 09:18 AM
Member Group: Members Posts: 54 Joined: 27-April 05 From: Charleston, WV Member No.: 3,992 Region Association: South East States |
It might be worth while to have a long talk with the previous owner who miss represented the engine! Not only the piston cylinders not as advertised but you never never use RTV in building a 914 engine.
Mark Henry |
Apr 29 2016, 09:24 AM
If you paid nickies coin for that you have been hosed.
I'd be just a tad pissy about it. |
boxsterfan |
Apr 29 2016, 09:29 AM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Who sold you the car and are they a member here on 914world?
iwanta914-6 |
Apr 29 2016, 09:34 AM
Senior Member Group: Members Posts: 718 Joined: 26-June 09 From: Minnesota Member No.: 10,510 Region Association: None |
More about this unfortunate event in this thread:
http://www.914world.com/bbs2/index.php?sho...=277029&hl= |
Mark Henry |
Apr 29 2016, 09:36 AM
It might be worth while to have a long talk with the previous owner who miss represented the engine! Not only the piston cylinders not as advertised but you never never use RTV in building a 914 engine. RTV is OK under the cylinders. Also a little RTV rubbed into paper gaskets (no excess) is OK as well. |
Mark Henry |
Apr 29 2016, 09:40 AM
More about this unfortunate event in this thread: http://www.914world.com/bbs2/index.php?sho...=277029&hl= (IMG:style_emoticons/default/blink.gif) |
Valy |
Apr 29 2016, 10:03 AM
It might be worth while to have a long talk with the previous owner who miss represented the engine! Not only the piston cylinders not as advertised but you never never use RTV in building a 914 engine. RTV is OK under the cylinders. Also a little RTV rubbed into paper gaskets (no excess) is OK as well. No, it's not ok at the registers. It means that when you torque the heads you actually measure the RTV elasticity. This will allow vibration in cylinders and heads worn the cylinders and create leaks when the RTV cracks. |
sixnotfour |
Apr 29 2016, 10:09 AM
914 Wizard Group: Members Posts: 10,412 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains |
Mark Henry |
Apr 29 2016, 10:38 AM
It might be worth while to have a long talk with the previous owner who miss represented the engine! Not only the piston cylinders not as advertised but you never never use RTV in building a 914 engine. RTV is OK under the cylinders. Also a little RTV rubbed into paper gaskets (no excess) is OK as well. No, it's not ok at the registers. It means that when you torque the heads you actually measure the RTV elasticity. This will allow vibration in cylinders and heads worn the cylinders and create leaks when the RTV cracks. (IMG:style_emoticons/default/rolleyes.gif) Over 25 years and hundreds of T1, T4, and /6 engines built, except for one cam/lifter related, no failures. How many engines have you built? |
Lo-Fi Version | Time is now: 27th April 2024 - 10:22 PM |
