What kind of Cylinders are these?, I bought a 914 with Nickies, but not sure what I received. |
HansJan |
Apr 28 2016, 08:03 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
The 1972 914 I bought is supposed to have 103mm Nickies (by LN-Engineering) with JE-forged pistons.
The car caught on-fire, so I had to remove the engine. After doing so I find that the cylinders are magnetic. Nickies are made from Aluminum, so this is suspicious. Is any of you able to recognize the make of the Cylinders in the below pictures. There is one picture with some marking on it. I do not want to disassemble the engine any further then needed. I only own this car for two weeks now, but going up a very steep learning-curve. very soon I will be able to help others. But for now I'm only asking questions. Br, Hans Jan |
r_towle |
May 2 2016, 04:55 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I think Chris is right, the 103's just about touch the studs and yours appear to have some room.
I have a set on my motor, but it is not something I could take a picture of at this point. Maybe McMark or Mark Henry could show you.....they both have/had 103 mm cylinders. Rich |
Mark Henry |
May 2 2016, 09:39 PM
I think Chris is right, the 103's just about touch the studs and yours appear to have some room. I have a set on my motor, but it is not something I could take a picture of at this point. Maybe McMark or Mark Henry could show you.....they both have/had 103 mm cylinders. Rich Nickies would be silver aluminum, a magnet will not stick to them, they would also have ARP head studs with 12 point nuts. (IMG:http://www.914world.com/bbs2/uploads/post-26-1455467774.jpg) This pic will give you an idea how much material is left when you machine for the 103 register. (IMG:http://www.914world.com/bbs2/uploads/post-26-1403278590.jpg) |
0396 |
May 2 2016, 10:25 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
I think Chris is right, the 103's just about touch the studs and yours appear to have some room. I have a set on my motor, but it is not something I could take a picture of at this point. Maybe McMark or Mark Henry could show you.....they both have/had 103 mm cylinders. Rich Nickies would be silver aluminum, a magnet will not stick to them, they would also have ARP head studs with 12 point nuts. (IMG:http://www.914world.com/bbs2/uploads/post-26-1455467774.jpg) This pic will give you an idea how much material is left when you machine for the 103 register. (IMG:http://www.914world.com/bbs2/uploads/post-26-1403278590.jpg) Boy, you even have the ARP case bolts too. Way too go . |
Mark Henry |
May 2 2016, 10:38 PM
Boy, you even have the ARP case bolts too. Way too go . Thanks, she is a brute in a 1700lb beetle. Made my my own heads as well, 44x38, SSI valves, dual springs with 12mm plugs...but then what do I know I use RTV.... (IMG:style_emoticons/default/confused24.gif) (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Lo-Fi Version | Time is now: 11th May 2024 - 01:25 PM |
