What kind of Cylinders are these?, I bought a 914 with Nickies, but not sure what I received. |
HansJan |
Apr 28 2016, 08:03 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
The 1972 914 I bought is supposed to have 103mm Nickies (by LN-Engineering) with JE-forged pistons.
The car caught on-fire, so I had to remove the engine. After doing so I find that the cylinders are magnetic. Nickies are made from Aluminum, so this is suspicious. Is any of you able to recognize the make of the Cylinders in the below pictures. There is one picture with some marking on it. I do not want to disassemble the engine any further then needed. I only own this car for two weeks now, but going up a very steep learning-curve. very soon I will be able to help others. But for now I'm only asking questions. Br, Hans Jan |
Mark Henry |
Apr 29 2016, 11:07 AM
Point is I've never seen a failure.
It was how Gene Berg did it, so that's good enough for me. Besides every builder has their favorites, some like curil-T, I've tried and think it's garbage. I have a couple unopened tubes if anyone wants it. Three bond I like, but quit using teflon dope on the PR seals, because I could see it when I cut open filters, now I use dow 55 which is way better, etc. |
JamesM |
May 2 2016, 11:46 PM
Senior Member Group: Members Posts: 1,895 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Point is I've never seen a failure. It was how Gene Berg did it, so that's good enough for me. Besides every builder has their favorites, some like curil-T, I've tried and think it's garbage. I have a couple unopened tubes if anyone wants it. Three bond I like, but quit using teflon dope on the PR seals, because I could see it when I cut open filters, now I use dow 55 which is way better, etc. The 2056 I picked up from Bruce, allegedly assembled by EMW had a good amount of orange RTV as well, I havent managed to blow the thing up yet and not for lack of trying. Seems you are not the only one that uses it with success. |
Lo-Fi Version | Time is now: 11th May 2024 - 02:50 AM |
