What kind of Cylinders are these?, I bought a 914 with Nickies, but not sure what I received. |
HansJan |
Apr 28 2016, 08:03 PM
Member Group: Members Posts: 395 Joined: 5-April 16 From: Sugar Land TX Member No.: 19,860 Region Association: Southwest Region |
The 1972 914 I bought is supposed to have 103mm Nickies (by LN-Engineering) with JE-forged pistons.
The car caught on-fire, so I had to remove the engine. After doing so I find that the cylinders are magnetic. Nickies are made from Aluminum, so this is suspicious. Is any of you able to recognize the make of the Cylinders in the below pictures. There is one picture with some marking on it. I do not want to disassemble the engine any further then needed. I only own this car for two weeks now, but going up a very steep learning-curve. very soon I will be able to help others. But for now I'm only asking questions. Br, Hans Jan |
r_towle |
May 4 2016, 09:52 PM
Custom Member Group: Members Posts: 24,574 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
If you look at some of the pictures in this thread, I believe what they are asking you to measure is the outer diameter of the liner/cylinder where it goes into the head.
That will be the honest outer diameter of the cylinder. If you measure in between the cooling fins you will be measuring casting material which won't be consistent and won't be a number they could use. Look at the pics in this thread....there is a 1/4 in tall exposed area on the top of the cylinder that fits into the head. The cylinders don't sit down tight in the heads, so you should be able to get a tool in between the top fin and the head. |
Lo-Fi Version | Time is now: 11th May 2024 - 12:29 AM |
