empty bank of relays |
JFG |
Apr 29 2016, 12:24 PM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
bretth |
Apr 29 2016, 12:28 PM
Senior Member Group: Members Posts: 899 Joined: 23-June 15 From: Central TX Member No.: 18,882 Region Association: Southwest Region |
These are part of the seat belt/ignition kill switch set up on the later dash seat belt light cars. I can take a pic of the ones on my 75 1.8 if it is useful to you.
Brett |
Mark Henry |
Apr 29 2016, 12:44 PM
The socket on the left looks a lot like a fuel pump relay from a VW FI bus. But looking at I can see its on the floor.
JFG |
These are part of the seat belt/ignition kill switch set up on the later dash seat belt light cars. I can take a pic of the ones on my 75 1.8 if it is useful to you. Brett I'd assume the previous owner has bypassed this seeing as the bank is empty and the wire has been jointed. I also noted the sensors in the seats were disconnected. |
914Sixer |
Apr 29 2016, 01:29 PM
Yes, it is the seat belt bypass. The bad is the wires were cut. All that was required was to unplug the spades from the block and plug them into a double male connector. Make sure you correct the twisted and splice. Put them in a butt connector.
74ravenna |
Apr 29 2016, 03:13 PM
Member Group: Members Posts: 471 Joined: 19-October 14 From: nh Member No.: 18,032 Region Association: North East States |
bretth |
Apr 29 2016, 04:29 PM
bretth |
Apr 29 2016, 04:32 PM
I just realized I only have the one connection block compared to your two.
Brett |
Apr 30 2016, 10:24 AM
You have found the Dreaded Seatbelt Interlock Relay. Or rather, what is left of it after the system has been disabled. It is better disabled.
The other socket might be for the "door ajar" buzzer. It was on my 74, but the buzzer was pathetic and annoying and it was pretty obvious when the door was open, so I removed that also. --DD |
Lo-Fi Version | Time is now: 18th May 2024 - 04:11 PM |
