JFG
Apr 29 2016, 12:24 PM
Final question for this eveni ng.
I found a bank of three relay connectors under the passenger seat. There is also a thick red/yellow wire that looks as though has been cut and rejoined.
Any info on these? I've tried reading my manual but i can't figure the diagrams out.
bretth
Apr 29 2016, 12:28 PM
These are part of the seat belt/ignition kill switch set up on the later dash seat belt light cars. I can take a pic of the ones on my 75 1.8 if it is useful to you.
Brett
Mark Henry
Apr 29 2016, 12:44 PM
The socket on the left looks a lot like a fuel pump relay from a VW FI bus. But looking at I can see its on the floor.
JFG
QUOTE(bretth @ Apr 29 2016, 06:28 PM)
Brett
I'd assume the previous owner has bypassed this seeing as the bank is empty and the wire has been jointed. I also noted the sensors in the seats were disconnected.
914Sixer
Apr 29 2016, 01:29 PM
Yes, it is the seat belt bypass. The bad is the wires were cut. All that was required was to unplug the spades from the block and plug them into a double male connector. Make sure you correct the twisted and splice. Put them in a butt connector.
74ravenna
Apr 29 2016, 03:13 PM
QUOTE(bretth @ Apr 29 2016, 02:28 PM)
Brett
Hi Brett,
I'd appreciate it if you did post a photo of yours.
Thanks
Steve
bretth
Apr 29 2016, 04:29 PM
Here is my 75. It may have been tampered with somewhat. The large black wire was disconnected at both ends and the original seats are long gone. The seat belt connectors have been disconnected by a previous owner.
bretth
Apr 29 2016, 04:32 PM
I just realized I only have the one connection block compared to your two.
Brett
Dave_Darling
Apr 30 2016, 10:24 AM
You have found the Dreaded Seatbelt Interlock Relay. Or rather, what is left of it after the system has been disabled. It is better disabled.
The other socket might be for the "door ajar" buzzer. It was on my 74, but the buzzer was pathetic and annoying and it was pretty obvious when the door was open, so I removed that also.
--DD
