new exhaust- how does it go on? |
johnpierre |
Apr 30 2016, 06:26 PM
Member Group: Members Posts: 401 Joined: 11-September 12 From: culver city, ca Member No.: 14,913 Region Association: Southern California |
hello everyone
looking for a little guidence before i take off my old exhaust. Bought this bursch one used and just want to ask a couple of questions before i get into wrenching. as per the photos it looks to me the bolts are part of the old exhaust and if that is so then presumably I need the bolts and nuts to put on the bursch??? Is there a recommended set of hardware that i need to purchase? Attached thumbnail(s) |
dangrouche |
Apr 30 2016, 08:29 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
my apology, IIRC they had two versions, the one you have and another type, rectangular. the one I have is rectangular and to me is loud, but I am pretty sure the you have there will be louder because there won't be that much for the exhaust gas to be diverted through. record your current sound with your phone and then play it back after you got this one installed. spray PB Blaster or WD-40 on the rusty threads of the existing nuts and bolts. Hardest part of the job will be finagling the thing in place before you tighten up all of the bolts. I use Permatex gasket anti-seize, in case I want to change back the exhaust to something else.
Here is the quieter street version: http://www.ebay.com/itm/Bursch-Muffler-Por...7S3&vxp=mtr |
johnpierre |
Apr 30 2016, 08:57 PM
my apology, IIRC they had two versions, the one you have and another type, rectangular. the one I have is rectangular and to me is loud, but I am pretty sure the you have there will be louder because there won't be that much for the exhaust gas to be diverted through. record your current sound with your phone and then play it back after you got this one installed. spray PB Blaster or WD-40 on the rusty threads of the existing nuts and bolts. Hardest part of the job will be finagling the thing in place before you tighten up all of the bolts. I use Permatex gasket anti-seize, in case I want to change back the exhaust to something else. got it and thanks. not too sure i will be into this new exhaust didn't want a louder one just a nice exhaust note and brusch was recommended to me a while ago. anyways i will rock this one out and if i don't like i then will sort it out later of put the old one back on.. IYHO what exhaust would you recommend for my 73, I am looking for something that sounds great not too loud, but then again if it is a little loud maybe that is a good thing, my car is not a DD and at some point i do want to build in a bit of performance... -jp- |
dangrouche |
Apr 30 2016, 10:08 PM
my apology, IIRC they had two versions, the one you have and another type, rectangular. the one I have is rectangular and to me is loud, but I am pretty sure the you have there will be louder because there won't be that much for the exhaust gas to be diverted through. record your current sound with your phone and then play it back after you got this one installed. spray PB Blaster or WD-40 on the rusty threads of the existing nuts and bolts. Hardest part of the job will be finagling the thing in place before you tighten up all of the bolts. I use Permatex gasket anti-seize, in case I want to change back the exhaust to something else. got it and thanks. not too sure i will be into this new exhaust didn't want a louder one just a nice exhaust note and brusch was recommended to me a while ago. anyways i will rock this one out and if i don't like i then will sort it out later of put the old one back on.. IYHO what exhaust would you recommend for my 73, I am looking for something that sounds great not too loud, but then again if it is a little loud maybe that is a good thing, my car is not a DD and at some point i do want to build in a bit of performance... -jp- I have a 2.0 liter and this is what I have on it now. but it is spendy. But it does give a nice deep throaty sound. In sequence of highest decibels, the Bursch you have is probably the loudest, then the rectangular bursch, then this Dansk gives the sound that is quieter and closest to OEM and give you the sound you seek. I'm speaking from experience from owning a 1.8 with a OEM exhaust 20 years ago and a 6 cylinder tail dragger. http://www.ebay.com/itm/Porsche-914-1972-1...58322?fits=Make |
Lo-Fi Version | Time is now: 17th May 2024 - 03:40 AM |
