New Custom Console Gauges, I made set up for me |
914Sixer |
May 2 2016, 05:55 PM
914 Guru Group: Members Posts: 8,870 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I had some NOS 52mm VDO gauges and figured it was time to play. I wanted a different but informative set of console gauges. You can open up the stock console gauges and take the gauge part out. Take the 52mm gauge part and drop it in the place of the larger gauge. Drop the 60mm stock ring on the outside, then drop the 52mm ring inside of it. Put glass and 60mm trim ring back on. Your done.
I cleaned the rings up for chrome look but they were pitted and will need replacement at NHS. What do you think? Attached image(s) |
somd914 |
May 2 2016, 06:58 PM
Member Group: Members Posts: 1,171 Joined: 21-February 11 From: Southern Maryland Member No.: 12,741 Region Association: MidAtlantic Region |
I've always liked the simplicity of VDO gauges of that era. With that said, however, I would prefer to have some digits associated with the temp gauge, perhaps to match the volt meter...
But neither here no there, I will say you do nice work! |
Kansas 914 |
May 2 2016, 07:24 PM
914Sixer |
May 3 2016, 03:51 PM
I have a spare pressure and temp gauge if any one is interested.
Lo-Fi Version | Time is now: 26th April 2024 - 02:24 PM |
