A duh... Moment, Pinging from engine (predetonation?) |
Dtjaden |
May 2 2016, 08:07 PM
Member Group: Members Posts: 232 Joined: 25-May 13 From: Morgan Hill, CA Member No.: 15,915 Region Association: Northern California |
I've been working the last few days getting my car ready for the WCR after it has had a few months winter rest. Some background: the engine is a 2056 with Megasquirt engine management, ignition and fuel injection.
Just before I put it to bed for the winter installed a cam position sensor, thanks to Mario at the Dub Shop. With the cam sensor I changed the ECU from semi-sequential FI to sequential and ignition from wasted spark to fully sequential. Today during a short drive I noticed engine was pinging under load. I tried backing of the advance a few degrees but that did not eliminate the problem. So the next step was to check the timing. I have an Innova variable timing light and it works correctly with wasted spark by setting the cylinder count to 2. Sitting here with a glass of wine (IMG:style_emoticons/default/beer3.gif) I just realized that the 2 cylinder setting on the timing light would result in the actual advance being twice as much as I thought...duh. I'll be back at it tomorrow to correctly set the timing and hopefully eliminate the engine's pinging. |
Bulldog9 |
May 2 2016, 10:20 PM
Senior Member Group: Members Posts: 705 Joined: 21-August 13 From: United States Member No.: 16,283 Region Association: MidAtlantic Region |
Well, I can start you in the right direction, dump that wine down the drain and go get a beer.......... (IMG:style_emoticons/default/beer.gif)
Lo-Fi Version | Time is now: 19th May 2024 - 08:53 AM |
