Kansas 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,999 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains ![]() ![]() |
Kansas 914 |
MoveQik |
What size wheels can I fit? ![]() ![]() ![]() ![]() Group: Members Posts: 4,654 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region ![]() ![]() |
When do you guys expect to be back to the hotel after the Friday drive? No need for us to rush up there to an empty hotel if you guys are gone all day. (IMG:style_emoticons/default/smile.gif)
Sleepin |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,647 Joined: 20-November 07 From: Grand Junction, Co. Member No.: 8,357 Region Association: Rocky Mountains ![]() |
When do you guys expect to be back to the hotel after the Friday drive? No need for us to rush up there to an empty hotel if you guys are gone all day. (IMG:style_emoticons/default/smile.gif) Well....if you drive through Durango and up through Silverton, don't you think you would notice 20 914's cruising around? I doubt they would be part of a different group. (IMG:style_emoticons/default/poke.gif) |
MoveQik |
When do you guys expect to be back to the hotel after the Friday drive? No need for us to rush up there to an empty hotel if you guys are gone all day. (IMG:style_emoticons/default/smile.gif) Well....if you drive through Durango and up through Silverton, don't you think you would notice 20 914's cruising around? I doubt they would be part of a different group. (IMG:style_emoticons/default/poke.gif) That adds an hour.... |
Kansas 914 |
When do you guys expect to be back to the hotel after the Friday drive? No need for us to rush up there to an empty hotel if you guys are gone all day. (IMG:style_emoticons/default/smile.gif) Well....if you drive through Durango and up through Silverton, don't you think you would notice 20 914's cruising around? I doubt they would be part of a different group. (IMG:style_emoticons/default/poke.gif) That adds an hour.... It is the best hour of the entire drive - but I am prejudiced. (IMG:style_emoticons/default/sunglasses.gif) |
Sleepin |
I bet we'd be back in Ridgway by 3 or 4.
JustinMeier |
Member ![]() ![]() Group: Members Posts: 244 Joined: 3-August 16 From: Scottsdale Member No.: 20,258 Region Association: None ![]() |
On the road!
Quick question on oil temps.. what's normal for the 2.7 and when should I start to worry? |
sixnotfour |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,928 Joined: 12-September 04 From: Life Elevated..planet UT. Member No.: 2,744 Region Association: Rocky Mountains ![]() ![]() ![]() |
Kansas 914 |
On the road! Quick question on oil temps.. what's normal for the 2.7 and when should I start to worry? according to your Dad it will vapor lock first.. 210 (IMG:style_emoticons/default/agree.gif) From Pelican: 180-210 is the proper range; 130 is too cool to dissipate water etc in the oil. 220-230 every now and then is fine; 250 isn't. Engine life drops quickly when oil temps consistently exceed 210. |
Ferg |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None ![]() ![]() |
I agree that 210 is optimal, but being a 2.7 I'm betting you will see 230 on the highway.
If it climbs up to 250 on sustained grades and then drops back into the 220-30 area that is what I would call normal for a 2.7 with no external cooler. |
Toast |
Not bad for carrying sway bars. ![]() ![]() ![]() ![]() Group: Members Posts: 3,380 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region ![]() |
SLITS car would occasionally get up to 2:50 if Running In the Heat of the day and on grades. It would usually drop down. But sometimes we would pull over and let it cool down for a bit.
sixnotfour |
SLITS car would occasionally get up to 2:50 if Running In the Heat of the day and on grades. It would usually drop down. But sometimes we would pull over and let it cool down for a bit. and add oil (IMG:style_emoticons/default/beer3.gif) |
Toast |
Just picked up a Huge Green River watermelon to cut in half and pour vodka in....
(IMG:style_emoticons/default/happy11.gif) |
JRust |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,317 Joined: 10-January 03 From: Albany Oregon Member No.: 129 Region Association: Pacific Northwest ![]() ![]() |
Hey I have a spare bedroom if anyone is still looking to sit a room
JustinMeier |
SLITS car would occasionally get up to 2:50 if Running In the Heat of the day and on grades. It would usually drop down. But sometimes we would pull over and let it cool down for a bit. and add oil (IMG:style_emoticons/default/beer3.gif) Speaking of adding fluids, where does the water go? |
Kansas 914 |
Speaking of adding fluids, where does the water go? (IMG:style_emoticons/default/w00t.gif) (IMG:style_emoticons/default/lol-2.gif) |
Sleepin |
SLITS car would occasionally get up to 2:50 if Running In the Heat of the day and on grades. It would usually drop down. But sometimes we would pull over and let it cool down for a bit. and add oil (IMG:style_emoticons/default/beer3.gif) Speaking of adding fluids, where does the water go? In your belly to hydrate in preparation to the punishment your body will receive in the next couple days. (IMG:style_emoticons/default/beer3.gif) |
JustinMeier |
It's ok, I found it under the front hood. Performance seems a little low now though (IMG:style_emoticons/default/confused24.gif) |
JustinMeier |
In your belly to hydrate in preparation to the punishment your body will receive in the next couple days. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/laugh.gif) |
Lo-Fi Version | Time is now: 21st August 2025 - 10:24 AM |
