FS Gas Tank 1970-1974 Very Clean $150 Bare tank, $250 Complete, Early Style Tank that uses a steel expansion tank |
bdstone914 |
May 7 2016, 03:00 PM
I pulled this tank from a 914 in a Pick a Part yard. It is a very clean tank with little surface rust and most of the original paint and white stamp markings intact.
I wiped down the outside and sprayed the inside with carb cleaner to remove most of the varnish that formed when the tank sat in the California sun with the last dap of gas in it. I have a set of cleaned nipples and nuts and will include them with new paper gaskets and a new screen. I can also supply a filler neck, expansion tank, fuel sender and or assemble it all with new gaskets. $150 Bare tank, $250 Complete. Prefer local pick up but will ship from 92505 CA Attached thumbnail(s) |
Lo-Fi Version | Time is now: 17th May 2024 - 01:28 AM |
