Koni adjustables..., ..where do you that have them set them? |
naro914 |
May 11 2016, 08:17 AM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
so now that we have Koni adjustables on Huey, I have no clue where to set them. I heard that for AX, set them full soft, and for track, closer to full hard.
22 mm Front sway bar 21 mm torsion bars 225# rear springs Thoughts? suggestions? I know there are a lot of other variables: tires, weight, driving style, hp, track, etc...but just looking for a vague starting point. The adjustment knob spins 2.5 ish turns, with no specific 'click' spots or numbers like most adjustable shocks have, so I have no clue where to start. Thanks! |
rhodyguy |
May 11 2016, 08:45 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Iirc, the paper work that came with mine, ext adj, was to not set them at full soft or hard.
Randal |
May 11 2016, 09:15 AM
so now that we have Koni adjustables on Huey, I have no clue where to set them. I heard that for AX, set them full soft, and for track, closer to full hard. 22 mm Front sway bar 21 mm torsion bars 225# rear springs Thoughts? suggestions? I know there are a lot of other variables: tires, weight, driving style, hp, track, etc...but just looking for a vague starting point. The adjustment knob spins 2.5 ish turns, with no specific 'click' spots or numbers like most adjustable shocks have, so I have no clue where to start. Thanks! For autox I set the front koni's 1/2 off full soft, rear about 3/4 turn off. I had the Smart racing front sway bar that I ran with the their 1" bar (60#-135#) and the adjustment was just an inch off full soft. Rear springs were 240# if I remember correctly. Ran this configuration for autox, Medford enduro and hill climbs. By the way use the search engine on this site and look for autox, autoxsetup, setup, smart racing, koni, shocks, etc. Lots and lots of posting about autoxset up. |
Lo-Fi Version | Time is now: 4th May 2024 - 09:05 PM |
