Nearly done, need help identifying these bits |
ntmatter |
May 12 2016, 10:50 PM
Newbie Group: Members Posts: 46 Joined: 10-May 11 From: Gig Harbor, WA Member No.: 13,049 Region Association: None |
Getting nearly done with my rustbucket restoration - rust cut out and new metal welded in, runs pretty well, new paint, and the final interior bits on the way from the (astoundingly helpful) 914rubber.com guys. While I'm waiting on my new backpad covering and vinyl seats, I have a small handful of assorted fasteners and these jobbies left on the workbench. I could use some help in identifying them from the cognizeti. I'm fairly sure that #1 is a vent thing for the front trunk, but the others have me stumped. Thanks for any advice!
Attached thumbnail(s) |
Garland |
May 12 2016, 11:03 PM
Restoration Fanatic Group: Members Posts: 1,329 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest |
1. Front trunk rear most drain hole.
2. .? 3. Peddle board stop 4. Hand brake cable cover, behind drivers seat. |
jcd914 |
May 12 2016, 11:04 PM
3 looks like the clutch pedal stop (attaches to the pedal board)
4 looks like the E-brake cable pivot cover (covers where the 2 cable hook to the e-brake handle) Jim |
914Sixer |
May 13 2016, 05:51 AM
914 Guru Group: Members Posts: 8,891 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
#2 is the drivers door box lid stop
May 13 2016, 07:04 AM
914-6 GT in waiting Group: Members Posts: 19,286 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
ntmatter |
May 13 2016, 09:38 AM
Awesome, thanks everyone! I'd pulled apart the driver's door to fix the cards and reupholster and totally forgot about this. For the trunk holes I just used extra of the rubber tube things (total of 3), so may not need to replace this bit.
JeffBowlsby |
May 13 2016, 10:35 AM
914 Wiring Harnesses Group: Members Posts: 8,517 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
#1 looks like one of two drain plugs at the forward engine bay shelf recesses at left and right. Right side = i.e. 'hell hole'
Lo-Fi Version | Time is now: 24th May 2024 - 11:02 PM |
