WTB VDO Temp gage w/numeric readout + sender, up grade to numeric VDO with sender |
wes |
May 14 2016, 01:40 PM
wes Group: Members Posts: 1,588 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
I want to up grade my stock 74 2.0 console oil temp gage to the VDO Numeric Type and accompanying Sender
Tom_T |
May 14 2016, 02:30 PM
Wes,
VDO sells them new, but the diameter of the gauge face is smaller than your stock one, so you'll also need the rubber adapter ring for it to fit the larger center console hole. The gauge & sender are available anywhere selling VDO instruments, & the usual 914 new parts sources, so just get the best price. I think that either VDO makes & sells the adapter rings, or else 914Rubber, Auto Atlanta, or others may have them. Another option that some with the 74-76 914s with the wide red band OT gauges did back in the 70's, was the take the OT manually with the gauge pointing at a certain place on the gauge, then put a tick mark, & repeat for the range (after a few readings you could extrapolate the rise). Some added white letters for temps., & others just memorized it. Today a laser heat gun makes this easy. Also, I think that North Hollywood Speedo &/or Palo Alto Speedo could do that for you as a custom gauge face for a stock OT gauge of the proper diameter. .... i.e.: it could be done as a numbered face. Oddly enough, the early 73 MY brochures for the 914s, shows a numbered OT gauge in the pic of the 2L's center console! Apparently they went with the KISS red band solution in the end. There are a few options for you to ponder! (IMG:style_emoticons/default/idea.gif) Good Luck! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
wes |
May 14 2016, 03:01 PM
Thanks Tom my problem is I have a new engine that ether has the wrong sending unite or isn't working so my stock gage is useless at this point.
In the end I would like to install a head temp gage, numeric oil temp gage, and oil pressure gage. Now WCR is in just a few days and with no working temp readout other than a oil dip stick gage on a complete new set up I'm not to excited about running my engine for fear of a Meltdown! (IMG:style_emoticons/default/hissyfit.gif) The Murphy's law comes into all this as I have a complete engine with I believe the right sender berried in the grange (IMG:style_emoticons/default/headbang.gif) that would take a week to get to dew to wife and kids junk (Oh ya I have my parts car and my unorganized parts stash in that mess as well). So Im just looking to buy and overnight (IMG:style_emoticons/default/confused24.gif) just dew to our (mostly my) unorganized Garage. |
boxstr |
May 14 2016, 03:14 PM
Is this kind of what you are looking for?
Craig at CAMP Attached thumbnail(s) |
wes |
May 14 2016, 03:26 PM
boxstr |
May 14 2016, 03:29 PM
Do want just the one gauge or the complete panel?
Craig |
boxstr |
May 14 2016, 03:40 PM
This gauge is installed in the stock size 914 fuel gauge.
bdstone914 |
May 14 2016, 04:00 PM
bdstone914 Group: Members Posts: 4,517 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
You need a sending unit marked 150 C. Ground the sender wire and it should peg the gauge proving the gauge works. North Hollywood speedo sells the senders. The gauges shown at 52mm and do not fit a stock 914 console . Also that temp gauge takes a different sender that does not fit the taco plate. Find out what you have before buying more parts that are not going to solve your problem.
wes |
May 14 2016, 04:15 PM
Thanks all Im on hold until Monday to be sure of what Im doing as it looks like I may be able to get what I want and actually need at Palo Alto Speedometer in person!
914Sixer |
May 15 2016, 08:42 AM
914 Guru Group: Members Posts: 8,877 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Is this what you want? I can build you one from your old gauge and supply the temp sender to go with it. You will have to have a new trim ring IF the old one does not come off ok. $99 shipped
Lo-Fi Version | Time is now: 9th May 2024 - 03:36 PM |
