Early muffler ID, Can you help me identify this muffler? |
Papermaker |
May 15 2016, 09:30 AM
Newbie Group: Members Posts: 35 Joined: 19-January 04 From: Custer WI. Member No.: 1,578 |
Hi--
I was told that this muffler is an early 911 muffler or possibly from an 914-6. In either case it is supposed to fit a 911, 914-6 or a conversion 914. Can anyone verify the muffler for me and let me know what it fits? Thanks, --Papermaker |
tomrev |
May 15 2016, 09:51 AM
Member Group: Members Posts: 231 Joined: 25-February 14 From: N. Mich. Member No.: 17,037 Region Association: None |
Looks like a Lietritz (maybe spelling is off), and could also be Dansk. I know the Lietritz was factory thru mid-70's on 911's.
Jeffs9146 |
May 15 2016, 09:58 AM
You need to look for this stamp.
Papermaker |
May 15 2016, 10:58 AM
Hi Jeffs9146--
I'm from the "It is better to curse the darkness a thousand times than to light a single candle" group. After looking a couple of times I found part number: BISHOFF 911 . 025 . 00 /0577. Can you tell what this is from and will fit? Thanks, --Papermaker |
Jeffs9146 |
May 15 2016, 11:04 AM
Hi Jeffs9146-- I'm from the "It is better to curse the darkness a thousand times than to light a single candle" group. After looking a couple of times I found part number: BISHOFF 911 . 025 . 00 /0577. Can you tell what this is from and will fit? Thanks, --Papermaker 1977, 1978 911. The date code is 0577 so it was first installed sometime after that date. It will fit just about anything that was two in one out. You can put it on a 914-6 but the tip will point down low. Some people cut and re-weld the tip to make it fit the rear valance better. |
Papermaker |
May 15 2016, 01:17 PM
Ok Jeff, thanks for the info.
--Papermaker |
porschetub |
May 15 2016, 02:27 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Lo-Fi Version | Time is now: 19th May 2024 - 01:30 AM |
