1972 914 |
1972 914 |
Zimmy |
May 15 2016, 07:00 PM
I'm new here ... Group: Members Posts: 0 Joined: 31-July 14 From: Canada Member No.: 17,712 Region Association: None |
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500
michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. |
Pat Garvey |
May 24 2016, 06:43 PM
Do I or don't I...........? Group: Members Posts: 5,899 Joined: 24-March 06 From: SE PA, near Philly Member No.: 5,765 Region Association: North East States |
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500 michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. OK, I'll be the asshat here. Why no VIN? Why no pics? Rules are rules. If they aren't enforced they aren't rules. Do we need Trump here? |
0396 |
Jun 28 2016, 08:20 AM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
1972 Porsche 914 1.7L 4cyl. Extensive mechanical restoration. Hell hole area clean and floors in good shape. Great project for restoration or drive as is. I can e-mail pictures upon request. Price: $8500 michael_zimmerman5@sympatico.ca - rebuilt engine bottom end including new bearings for rods, crankshaft, and cam - drilled and pipe plugged oil galleries - new oil seals - thermostat cable - cylinders, pistons and rings 96mm (1910cc) -proper compression ratio calculated and barrel shims installed -cylinder heads rebuilt by Bill @motex (valve, guides, seats and valves) - elephant feet valve adjusters -all sheet metal media blasted and re-paint -dual 40mm HPMX carb kit -ignition wires, cap,rotor and plugs - 3 oil changes, one after engine break in, one after first 100 kms and one before storage this past winter -end play on crankshaft and flywheel set to spec -flywheel and clutch assembly inspected,cleaned and reinstalled -transmission overhauled with new seal/gasket kit -this is a side shift 5 speed -1st and 2nd gear syncros replaced -installed good used 1st reverse slider -new synthetic oil -new braided ground strap -drive shafts and cv joints cleaned and inspected -4 new cv joint boots and grease kits/clamps -all new shifter bushings and boots -gas tank removed/cleaned and painted with 2 stage paint -new fuel lines and proper german clamps - new fuel pump and filter -cut out front steering rack support on right side of car and weld in a good used support I sourced from the USA. paint and undercoat -sourced master cylinder/steering rack under tray from USA and paint, install with new hardware - ATS rims blasted and repainted in 2 stage silver/clear -new tires -front and rear brake calipers/pistons and hardware cleaned, blasted and yellow zinc coated/black oxidecoated -front and rear caliper rebuild kits with e-brake kits -e-brake cables and pins -front and rear brake pads -turned and painted brake rotors, rotor hats painted in 2 stage paint -repacked front bearings with new grease seals -all new rigid brake lines including center tunnel line with fittings -new master cylinder with rubber connector lines -braided front and rear brake hoses -media blasted spare tire rim and pain, installed good used spare tire, valve stem and balance -new alternator and belt -new stater motor -new battery -newer radio with cd player -drive car and shake down, adjust and make sure everything works mechanically. OK, I'll be the asshat here. Why no VIN? Why no pics? Rules are rules. If they aren't enforced they aren't rules. Do we need Trump here? Here's the rules / guidelines for your reference: Rules!, Return to the forum We've established the following guidelines to help make your sales/purchases as successful as possible! - Please List WTB:, FS:, TRADE: etc (want to buy, for sale, and trade respectively) before your add title. - Please put a price in your ad and state how you would like payment. - If you'd like to bump your ads, feel free to do so every two days. - DO NOT MAKE YOUR ADS IN ALL CAPITAL LETTERS! It's considered rude. - All eBay ads belong in the eBay category. - Please consolidate your ads into one big lump... listings and pictures together in one thread. Please be considerate of other classified users!! |
Lo-Fi Version | Time is now: 27th May 2024 - 02:48 AM |
