Which Tach do I use????, XR700 upgrade |
jtf914 |
Jun 19 2003, 07:49 AM
Member Group: Members Posts: 428 Joined: 31-December 02 From: Burlington, CT Member No.: 58 Region Association: North East States |
I recently switched to the crane xr700, and of course my tach is no longer working. Which tach do I need to use now, or is there a way to get my current tach operational again?
The tach currently in the car is not original, it was changed when the engine was rebuilt, and it was wired directly from the points signal (no ballast resistor). When I hook this tach to the negative side of the coil it reads way too high. Any suggestions???? Thanks! (IMG:style_emoticons/default/beer3.gif) |
Steve Thacker |
Jun 19 2003, 08:27 AM
UMMMPH Yea Baby Yea ! UMMMPH Group: Members Posts: 1,089 Joined: 8-January 03 From: Pickerington, Ohio Member No.: 113 Region Association: Upper MidWest |
Justin,
I run the same Crane unit. I however run the standard tach. What I suggest is that you need to order the correct resister /adapter from Crane for your tach application. It would be even more ideal to get a original tach if possible and use that. You don't need to any hookus pookus on it to get it to work. |
jtf914 |
Jun 19 2003, 11:06 AM
Thanks Steve. I took a look at their website and only found a tach adapter for the HI-6 unit. I gonna call their tech line and see it I can still use the adapter with the xr700. Thanks for the info (IMG:style_emoticons/default/beerchug.gif) .
StratPlayer |
Jun 19 2003, 01:28 PM
StratPlayer Group: Members Posts: 3,278 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
They have to versions of the tac adapter:\
Prt # 6000-8910 6000-8920 |
Lo-Fi Version | Time is now: 20th May 2024 - 10:39 AM |
