Oil Pressure Check Valve, STUCK |
JOEPROPER |
May 16 2016, 05:15 PM
The answer is "no" unless you ask... Group: Members Posts: 1,184 Joined: 21-November 15 From: White Plains New York Member No.: 19,387 Region Association: North East States |
So, I'm prepping my 2.0 case for rebuild and I'm having a hard time with removing the oil pressure check valve. I have the big screw and spring out, but can't seem to remove the check valve. It's been soaking in PB Blaster for 2 days now and still nothing. I'm hoping someone has come across this and has "the trick". Any help is greatly appreciated.
Sorry to waste your time if this has been covered, but I couldn't find it. Thanks, Joe Never mind... I got it. Threaded a 1/2" bolt onto the check valve and slide hammered it out. Thanks anyway. |
yeahmag |
May 16 2016, 08:07 PM
Advanced Member Group: Members Posts: 2,421 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
Get one of the replacement kits for this. If memory serves Chris of Tangerine Racing has a new version out.
May 16 2016, 08:50 PM
You have issues with the bore if you needed to extract it with that level of force
JOEPROPER |
May 17 2016, 06:05 AM
You have issues with the bore if you needed to extract it with that level of force I was planning on cleaning up the bore and valve with fine emory cloth... I would welcome any suggestions. I'm sure this is a critical area and don't know how else to can measure the bore. |
reharvey |
May 17 2016, 06:40 AM
Senior Member Group: Members Posts: 573 Joined: 16-July 08 From: N. E. Ohio Member No.: 9,308 Region Association: North East States |
If you have the right size tread tap screw it into the hollow backside of the valve. It'll grab hold of it so you can pull it out. Works every time. Ray
JOEPROPER |
May 17 2016, 07:38 AM
If you have the right size tread tap screw it into the hollow backside of the valve. It'll grab hold of it so you can pull it out. Works every time. Ray Yes, I did just that. I'm now concerned about the check valve bore, so with the recommendation of another member, I've looked into the Tangerine Racing upgraded oil pressure relief system. Looks like a simple solution. Thanks. |
Lo-Fi Version | Time is now: 18th May 2024 - 10:06 PM |
