Loose fan belt on /6, and only one day till WCR |
PanelBilly |
May 17 2016, 07:13 PM
914 Guru Group: Members Posts: 5,809 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Nate took care of adjusting the valves on my engine Monday and noticed that my fan belt was loose. He didn't have the tool for holding the outside half of the pulley, but I did at home.
So, tonight I pulled off the pulley and found that the mounting hole that should have been round with 2 flat sides had become just round. A call to John Walker in Seattle confirmed that this is a result of the bolt not being on tight enough. The outer pulley is toast now, but John said he had a used one I can pick up tomorrow. The worst of the news is that the inner half of the pulley is also the fan and that I've got some grooves cut into it from the friction. I think I can make it work for now. I hope so Inner half of pulley that is part of the fan The outer half of the pulley that was slipping |
May 17 2016, 07:28 PM
914-6 GT in waiting Group: Members Posts: 19,295 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
The fan side is pretty thick. You should be ok. Good thing you caught it now.
type2man |
Member Group: Members Posts: 353 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
If you put more shims , then the outer half of the pulley will contact the good area of the fan that is not worn out. Belt might be loose but the pulley wont fall apart. I think you can shim the fan so it sits higher and the belt can be tighter and you should be good to go.
May 17 2016, 07:30 PM
Custom Member Group: Members Posts: 24,584 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Wtf are those pieces?
PanelBilly |
May 17 2016, 09:27 PM
The second one is scrap metal now
brant |
May 17 2016, 09:55 PM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
No blinking alt light? That is bad. Did it slip?
May 17 2016, 09:58 PM
Seriously, what are the metal wires?
My 3.2 is loose.....thought it was just shims... Like all the other aircooled ones I have ever touched. |
May 17 2016, 10:04 PM
Resident German Group: Admin Posts: 41,658 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Seriously, what are the metal wires? It's his girlfriends fancy hand mirror .. (IMG:style_emoticons/default/biggrin.gif) |
2mAn |
May 17 2016, 10:05 PM
trying to see how long I can go without a 914 Group: Members Posts: 487 Joined: 14-November 13 From: Westchester (Los Angeles) Member No.: 16,644 Region Association: Southern California |
May 17 2016, 10:08 PM
Seriously, what are the metal wires? It's his girlfriends fancy hand mirror .. (IMG:style_emoticons/default/biggrin.gif) Doh! I did not see that... |
PanelBilly |
May 17 2016, 10:09 PM
I'm using a mirror from the bathroom and the wires are part of the mirror. It an illusion. Walker said there should be about a half an inch of deflection in the belt. Also that if I try to turn the fan blades it should be difficult because of the tension. I have a digital volt meter and is was showing a charge the whole time.
Dominic |
May 17 2016, 10:55 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
Not sure if this would cure your problem but Rothsport makes a real nice billet aluminum outer pulley half...
http://www.rothsport.com/Products/Engine/F...911-(65-75).htm |
6freak |
May 18 2016, 09:28 AM
I'm using a mirror from the bathroom and the wires are part of the mirror. It an illusion. Walker said there should be about a half an inch of deflection in the belt. Also that if I try to turn the fan blades it should be difficult because of the tension. I have a digital volt meter and is was showing a charge the whole time. easy fix billy get the parts ill come help you tonight after i get loaded |
Chris H. |
May 18 2016, 01:49 PM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Seriously, what are the metal wires? It's his girlfriends fancy hand mirror .. (IMG:style_emoticons/default/biggrin.gif) Doh! I did not see that... I know...I was like WTF is that wire clippy thing (IMG:style_emoticons/default/confused24.gif) ? |
Cairo94507 |
May 18 2016, 03:40 PM
Michael Group: Members Posts: 9,791 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
Get loaded.... (IMG:style_emoticons/default/beerchug.gif)
rgalla9146 |
May 18 2016, 04:50 PM
Advanced Member Group: Members Posts: 4,560 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I'd remove the fan, weld the damaged areas, grind, file, reassemble.
New outer pulley too. |
jcd914 |
May 18 2016, 05:49 PM
I don't know if it is my eyes or your picture but I don't see enough damage to the inner pulley half/fan to be concerned with.
Make sure you have enough pulley shims in place when you put it back together. Without enough shims, the cupped washer can bottom out on the pulley hub and not hold the outer pulley half in place tightly. There is a minimum number of shims required, I don't remember the number. Jim |
PanelBilly |
May 18 2016, 08:15 PM
Got a new outer pulley and a new belt from John. He also gave me a lesson in how to do it. Turns out that the belt I had on it was too big. Got it all together now and it's working.
May 18 2016, 08:51 PM
There is a minimum number of shims required, I don't remember the number. The "extra" shims go on the outside of the pulley, between the outer half and the nut. Failing to do that can cause problems... I forget what they are, but at the very least I could see the possibility of running out of threads. --DD |
zambezi |
May 18 2016, 09:46 PM
Senior Member Group: Members Posts: 711 Joined: 14-April 08 From: Lafayette, LA Member No.: 8,920 Region Association: South East States |
This is a common problem in the 356 world. The 356 pulleys require 10 shims total. If you only need 5 shims to get a tight belt, then the other 5 shims HAVE to go on the outside of the pulley or the nut will not clamp the whole assembly properly and the pulleys will self destruct after not long.
Lo-Fi Version | Time is now: 27th May 2024 - 11:18 PM |
