feelers-autox car |
feelers-autox car |
jjackson |
May 19 2016, 10:28 AM
Member Group: Members Posts: 219 Joined: 5-October 10 From: maumelle, arkansas Member No.: 12,246 Region Association: None |
Sixth child on way.No time for autocrossing.SCCA FP car currently.
Solid chassis-Cage tied into rear shock towers.Boxed trailing arms-stiffening kit- Trailing Arm Attachments strengthened (Tangerine) adjustable triangle bracing(Tangerine) 2.4L twin plug six (1st overbore)standard bearings Fuel Injected- PMO throttle bodies electromotive tech 3 12.5 to 1 JE's 5.5 inch patrick motorsports twin disk clutch Elephant racing bearings front and rear JRZ shocks with coilovers -double adjustable (Valved by Greg Fordahl) TRG front swaybar J West shifter -complete Guard Limited Slip 904 main shaft-aluminum intermediate plate Currently c gear in second and I gear third 944 front brakes-914 fronts on rear (PROPORTIONING VALVE) fuel cell Currently running Gotti wheels- 15 X 9' s and 11's Two sets of 16 X10s (real and duralites) five lug steel flares (modified) Car does not need to sit in trailer-Thanks for looking.Rattle can primer grey extrerior Car was third in FP 2010 SCCA national championships Thanks J Jackson |
tp_reading |
May 19 2016, 02:17 PM
Member Group: Members Posts: 58 Joined: 4-May 15 From: United Kingdom Member No.: 18,698 Region Association: None |
Sixth child on way.No time for autocrossing.SCCA FP car currently. Solid chassis-Cage tied into rear shock towers.Boxed trailing arms-stiffening kit- Trailing Arm Attachments strengthened (Tangerine) adjustable triangle bracing(Tangerine) 2.4L twin plug six (1st overbore)standard bearings Fuel Injected- PMO throttle bodies electromotive tech 3 12.5 to 1 JE's 5.5 inch patrick motorsports twin disk clutch Elephant racing bearings front and rear JRZ shocks with coilovers -double adjustable (Valved by Greg Fordahl) TRG front swaybar J West shifter -complete Guard Limited Slip 904 main shaft-aluminum intermediate plate Currently c gear in second and I gear third 944 front brakes-914 fronts on rear (PROPORTIONING VALVE) fuel cell Currently running Gotti wheels- 15 X 9' s and 11's Two sets of 16 X10s (real and duralites) five lug steel flares (modified) Car does not need to sit in trailer-Thanks for looking.Rattle can primer grey extrerior Car was third in FP 2010 SCCA national championships Thanks J Jackson How much are you asking? Any pics please ? |
jjackson |
May 19 2016, 02:29 PM
Sixth child on way.No time for autocrossing.SCCA FP car currently. Solid chassis-Cage tied into rear shock towers.Boxed trailing arms-stiffening kit- Trailing Arm Attachments strengthened (Tangerine) adjustable triangle bracing(Tangerine) 2.4L twin plug six (1st overbore)standard bearings Fuel Injected- PMO throttle bodies electromotive tech 3 12.5 to 1 JE's 5.5 inch patrick motorsports twin disk clutch Elephant racing bearings front and rear JRZ shocks with coilovers -double adjustable (Valved by Greg Fordahl) TRG front swaybar J West shifter -complete Guard Limited Slip 904 main shaft-aluminum intermediate plate Currently c gear in second and I gear third 944 front brakes-914 fronts on rear (PROPORTIONING VALVE) fuel cell Currently running Gotti wheels- 15 X 9' s and 11's Two sets of 16 X10s (real and duralites) five lug steel flares (modified) Car does not need to sit in trailer-Thanks for looking.Rattle can primer grey extrerior Car was third in FP 2010 SCCA national championships Thanks J Jackson How much are you asking? Any pics please ? $30,000.00-Will take pictures this week.Thanks |
jjackson |
May 19 2016, 02:32 PM
Just a few more details...
factory oil tank Rich Johnson six mount Brad Roberts axle and cv upgrade |
Randal |
May 19 2016, 04:32 PM
Don't you want to put details in the classified section as well?
jjackson |
May 19 2016, 08:05 PM
hot_shoe914 |
Jun 12 2017, 10:36 PM
on ramp passer Group: Members Posts: 3,802 Joined: 20-November 07 From: Earle, Ar. Member No.: 8,354 Region Association: None |
Lo-Fi Version | Time is now: 26th April 2024 - 10:10 PM |
