2 Pages V < 1 2
> Newbie with a 1973 2.0
napasteve
post Jun 7 2016, 08:58 PM
Post #21
914 driving winemaker
I just installed SS fuel lines from Tangerine Racing and a new Bosch 69133 fuel pump that I bought on Amazon for $72. Fuel lines can be installed with the engine in place (by a non-mechanic; if I can do it, anyone can). Wix 33274 or Purolator F23175 fuel filters both work and are available at Amazon for under $10.
Rathguten
post Jun 7 2016, 10:01 PM
Post #22
Thanks! Now being that there are three ports on my original fuel pump, how do I plumb the type shown in the picture with just two? I'm assuming I just need to remove the splitter from the return line, but I want to be sure.
napasteve
post Jun 8 2016, 08:18 AM
Post #23
Yes, just remove the spliter so the return line is a straight shot back to the gas tank. I had to move the pump from the original position; no way it would fit in the original spot with input and output on opposite ends of the new pump. I drilled a hole in the firewall (actually 2 walls) and mounted as shown in my previous picture. I just copied what another 914World member did (I need to search around to figure out what thread/member I got the picture below from).
Rathguten
post Jun 18 2016, 05:27 PM
Post #24
Well today I braved 100+ degree heat and installed a new fuel pump, new rubber lines, and the injectors I had repaired by Mr. Injector. After priming the system I hit the key and it started perfectly. I did a quick pre-flight and despite having no brakes went for a ride around the block. I typically work with 36hp VWs so I was really surprised at the responsiveness and power of the 2.0. A big thank you to those that shared their insight and advice. Now that I know it runs, I'm going to fix the brakes and then address the rust. I will update as I progress.
JawjaPorsche
post Jun 18 2016, 06:27 PM
Post #25
QUOTE(napasteve @ Jun 8 2016, 10:18 AM) *
That picture is from my 914. Feel free to use it to educate other owners. Terry
green914
post Jun 18 2016, 06:33 PM
Post #26
need to replace the plastic fuel line on mine too. (IMG:style_emoticons/default/welcome.png)
2 Pages V < 1 2
- Lo-Fi Version Time is now: 5th July 2025 - 12:36 AM
